ignition sparks....need help
Old Jan 21, 2007 | 09:19 PM
CNSK's Avatar
Default ignition sparks....need help
ok....I just got a 98 stock prelude vtec for 5-6 months and its been running fine til yesterday. Now my car wont start anymore. Motor is virgin and never been touch. I have no clue whats going on and I dont know what to do anymore. It cranks like its about to start but it just wont start. NO CEL
Ive check the following:
-Timing belt has not snap
-check fuses
-changed the module inside the distributor, still no spark
-changed the 5th spark plug ignition coil and still no spark
-change spark plugs
-turn the key and I can hear the fuel pump
could it be the main relay? if so where is it located? Should I changed the whole distributor? its a bit pricey thats why I changed the controll module inside the distribuotor and still no spark....
sorry for the newb question....Im not a H series guy.....more of a B series guy but I think its similiar........
any inputs or advice is greatly appreciated.....
Old Jan 21, 2007 | 09:25 PM
BlueLude84's Avatar
Default Re: ignition sparks....need help (CNSK)
haha, it sounds like what my car just went through.
I had to change the Electronic Ignition Switch.
So does your car actually start up, but dies after u let off the ignition?
Old Jan 22, 2007 | 06:03 AM
CNSK's Avatar
Default Re: ignition sparks....need help (BlueLude84)
nope....its doesnt start up at all....
Old Jan 22, 2007 | 10:20 AM
CNSK's Avatar
ttt
Old Jan 22, 2007 | 03:20 PM
CNSK's Avatar
come on....someone's gotta help me.....
Old Jan 22, 2007 | 06:17 PM
CNSK's Avatar
help......
Old Jan 22, 2007 | 06:28 PM
thegeorge613's Avatar
I remember something about an ignition switch recall on the 5th gen. Your car might not have gotten it done. This is just a guess, though.
Old Jan 22, 2007 | 07:13 PM
CNSK's Avatar
Default Re: ignition sparks....need help (thegeorge613)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegeorge613 &raquo;</TD></TR><TR><TD CLASS="quote">I remember something about an ignition switch recall on the 5th gen. Your car might not have gotten it done. This is just a guess, though.</TD></TR></TABLE>
pm you
Old Jan 23, 2007 | 07:05 PM
CNSK's Avatar
took it to local honda here....they said it will take 2-3hrs to figure the problem...now my car is sitting over night because they dont know whats wrong with it and need more time.....
bump for a solution....
Old Jan 24, 2007 | 09:12 AM
DOHC4VTEC's Avatar
make sure to post what it is if they find out
Old Jan 24, 2007 | 11:59 AM
CNSK's Avatar
Default Re: ignition sparks....need help (DOHC4VTEC)
they got called me and say it could be my the car key causing the ignition to shut down on me or something like that ...who knows, there's no honest shop these days......
my question is:
I have 3 keys to the car and 2 keys are black while one has a pink on it......could the spare pink key cause my car to shut down? All the keys are honda oem chipped keys.
Could my ecu go bad?
help
j4yzn
Aug 24, 2009 12:45 PM
billllll23integra
Apr 6, 2008 11:08 AM
dan89crxsi
Feb 10, 2007 02:44 PM
stunt_driver
Jun 8, 2005 04:55 AM
