e motor trani ecu and harnesswhats left for the swap???
Old Jan 21, 2007 | 08:12 PM
crxnonvtec's Avatar
Default e motor trani ecu and harnesswhats left for the swap???
ok I got a 91 crx d15b2 auto......I stole the motor trani. ecu harness pedal assembly resistor box throttle and clutch cables from a 90 ex I bought....now an ex friend left a d16z6 assembled head with cams and a d16a6 block...what would I need to buy to run the vtec setup????
Old Jan 21, 2007 | 09:08 PM
oodie's Avatar
Default Re: e motor trani ecu and harnesswhats left for the swap??? (crxnonvtec)
just search mini me and you will find all the anwsers
Old Jan 21, 2007 | 09:12 PM
e jay one's Avatar
Default Re: e motor trani ecu and harnesswhats left for the swap??? (oodie)
you first gota rewire it to mpfi then convert it to obd1 get a p28 ecu, or run it gheto and leave it obd0 and get a vtec controler. then convert it to a 5 speed. if you still need help first search dpfi to mpfi, then search obd1 conversion, then search auto to manual swap. its gona be a bit of work but not realy too hard if you good at wireing. the pedals are a bitch to get off though.
ridegreen02
Jul 22, 2011 10:39 AM
civicxxman
11
Mar 2, 2008 05:40 AM
93egryda
Mar 14, 2006 02:53 PM
CRX_Type_R
Nov 8, 2004 02:41 PM
91d15bvtec
Aug 30, 2004 06:02 PM
