d15b into 97 EX questions
Old Jan 21, 2007 | 07:46 PM
dustin_shull's Avatar
Default d15b into 97 EX questions
I got a 97 EX coupe and my d16y8 finally give out. I ordered a d15b short block and was just wondering what i need to do to make it run. I still have all my d16y8 stuff but someone told me I need to get a p28 ecu and switch over to obd1 OR I could just switch my y8 head onto the d15b and plug everything back like it was.
Is any of that true???
Old Jan 21, 2007 | 09:30 PM
e jay one's Avatar
Default Re: d15b into 97 EX questions (dustin_shull)
yes all of it is true. i would use your y8 parts and keep it obd2 for the conservation of money. just put your y8 intake mani on the d15b and ghetto rig your y8 dizzy on there or try and rewire the d15b one to plug into your obd2 plugs if thats possible i dont know much about obd2 its past my time. but dont convert to obd1 unless you want to waste money.
Old Jan 22, 2007 | 05:02 AM
Default Re: d15b into 97 EX questions (e jay one)
so let me get this straight, all i have to do is swap my harness on the d15b,swap my y8 manifold on it, and just hook everything back up like it was?
Old Jan 22, 2007 | 12:09 PM
bump 4 reponse asap!
Old Jan 22, 2007 | 12:17 PM
aznej2's Avatar
Y8 parts = distributor, alternator, wiring harness, injectors,
transfer those parts to your d15b i dont know why you would need to transfer the intake manifold... other than that though everything should bolt right up. Some jdm vtec solenoids are different than usdm so if ur harness doesnt plug into the vtec solenoid transfer from the y8 to the d15b
Old Jan 22, 2007 | 01:03 PM
Default Re: d15b into 97 EX questions (aznej2)
Thanks!!!! I let ya'll know if i have any problems with anything.
Old Jan 24, 2007 | 07:39 AM
aznej2's Avatar
ok sounds good... good luck
bigpwr
Jun 19, 2010 11:20 PM
pjr710
Aug 12, 2008 03:28 PM
99_itr
13
Dec 24, 2007 10:24 PM
dunkd
14
Jan 31, 2006 04:36 AM
rasinhell
Jan 29, 2005 10:27 AM
