Popping noise from exhaust
Old Jan 21, 2007 | 07:33 PM
ceehris's Avatar
Default Popping noise from exhaust
I have a 88 Lx with a d16z6 obd1 swap. I am hearing a popping noise from the exhaust. I also have one loud valve. so I am going to adjust the valves tommorow. do you think this popping noise could be from a valve out of adjustment?? or am I most likely gonna have to rebuild the head??
Old Jan 21, 2007 | 07:44 PM
betsy84's Avatar
Sounds like your car is backfiring to me. What are you running for an exhaust? If you bounce the revs up high it'll pop from what I understand I never do it to my car. Perhaps your timing needs adjusted.
Old Jan 21, 2007 | 07:54 PM
drnknmnky13's Avatar
Default Re: Popping noise from exhaust (ceehris)
Is it popping on deceleration? If so it might be running too lean.
Old Jan 21, 2007 | 08:35 PM
ceehris's Avatar
yes its on deceleration. it is best heard when the vehicle is idling. as for running lean. it makes the noise hot or cold so I dont think that would be the case. as for my timing, I just adjusted the other day its good. I sort of heard the noise when I first started driving the car and it was very very quiet. I do constantly rev the motor to about 6000rpm. the noise has gotten louder in the past couple days though. I have not had a problem with the car and ive been driving it for about a month now.
Old Jan 21, 2007 | 08:54 PM
oakpwr's Avatar
Default Re: (ceehris)
are you sure you dont have a hole in your exhaust piping somewhere?
Old Jan 21, 2007 | 09:56 PM
ceehris's Avatar
Default Re: (oakpwr)
no holes in exhaust
Razor
Mar 30, 2017 04:49 AM
AudioFunk
Jan 19, 2014 07:35 AM
GSRrR
Nov 5, 2001 09:03 PM
COREY ITR#625
Jul 3, 2001 09:08 PM
