first run w/turbo 8 psi stock engine - 14.6
not bad only 8 psi stock engine. modified or basically custom kit by me using sf kit and some racing hamsters.trap was about 98 and i ran 14.6 on 17 lbs 17 inch show rims..ill be hitting 13's by next event. bossting 10-12 with a valve train upgrade and stage 2 turbo cam.
wut u guys think.takea look
reppin WYLDKARDZ!!!
http://youtube.com/watch?v=tk3f_D4zRpo
Modified by kuki22 at 3:16 PM 2/2/2007
wut u guys think.takea lookreppin WYLDKARDZ!!!
very nice man
do you have anymore stats on the car? what is the turbo set-up? what was it tuned on? what size tires were you using?
also do you have the break down of the run, 60 ft. time, etc.?
good luck on hittin the 13s
tuned by ( dsmtuner ) w emanage. t3/t4 turbo..custom built kit by emME
.well modified it was a sf kit that baesed everything of off. and i knoe ill get 13'shehe
my shows rims 17 inch weight prolly 17-20 lbs each lols. ill get a copy of the slips up soon.
Modified by kuki22 at 3:15 PM 2/2/2007
Modified by kuki22 at 3:18 PM 2/2/2007
Modified by kuki22 at 3:43 PM 2/2/2007
Modified by kuki22 at 9:00 PM 2/2/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuki22 »</TD></TR><TR><TD CLASS="quote">tuned by me w emanage. t3/t4 turbo..custom built kit by me.well modified it was a sf kit i baesed everything of off. and i knoe ill get 13'shehe
my shows rims 17 inch weight prolly 17-20 lbs each lols. ill get a copy of the slips up soon.</TD></TR></TABLE>
What rims do you have? Because I doubt those weigh 17lbs.
get some 15x7's and 225's....
GEt ur 60's down to 2.1's and ull hit 13's no problem.
Also, sounds like u need a little work on the shifting, but that only comes with practice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuki22 »</TD></TR><TR><TD CLASS="quote">thanks to all..orderin pistons n rods tomrrow</TD></TR></TABLE>
must be nice to have that much money, lol. anyways good luck with the project and let us know how it turns out. oh yeah, def get rid of the emanage. and one more question, is you car a DD, if so when is the turbo spoolin and when do you hit full boost?
d17a2!!!!!! im reppin dat sohc baby!!! single cam power....i got a system to playuh full sytem in giant box wit 2 12's hehe im a show car that has some go 2 it!!!
turbo spools at about 4.2
what is ted'S sn !!!!!!!!!! its a d17 a2 tuned by street my a dsm guy!!!!using a dynoed base map from dynospot from a NON V TEC 4 DOOR!
Modified by kuki22 at 8:39 PM 2/2/2007
Modified by kuki22 at 8:41 PM 2/2/2007
