96 Civic Coupe Fully Built Turbo F/S
Old Jan 21, 2007 | 05:35 PM
BadA$$Si's Avatar
Default 96 Civic Coupe Fully Built Turbo F/S
Here is a list of the mods, this is everything I can think of right now:
Head:
Full Race Port and Polish
4 Angle Valve Job
Zex Valve Springs and Retainers
Ferrea Valves
D16z6 Manifold with a GSR Throttle Body
B&M Fuel Pressure Regulator and Gauge
450 DSM Injectors
ARP Head Bolts
Cosmetic 40mm Head Gasket
Block:
Srp 9:1 Compression Piston 75.5 Bore
Eagle Rods
ACL Race Bearing
Tranny:
D16y8 Tranny
Stage 4 ACT 4 Puck Clutch with a Extra Extreme Presure Plate
Turbo:
T3/T4 Turbo
38mm Wastegate
Drag Turbo Manifold
3 Inch Exhaust
Front Mount Intercooler
Mendral Bend Aluminum Charge Pipes
Interior:
JDM Type R Recaro Seats
Boost, Air Fuel, Oil Press., Voltage Gauges
Si Cluster
OBD2 to OBD1 Jumper Harness with a chipped P28 ECU with Crome
Exterior:
2000 Front
Blue 16 Inch Gt3's
Rear Disc Conversion
Blox Rear Lower Control Arms
Cross Drilled Rotors
Tokico Suspension
Front and Back Lips
If any questions I can be contacted at 215-520-8419
I am asking 6300 OBO. No Trade Cash only and car will not be parted out.
BadA$$Si
Northeast (Sales)
Jan 22, 2007 04:31 PM
proclass
Nov 24, 2006 10:02 PM
Mulan
Dec 1, 2003 04:01 PM
