B16B head on B16a SiR II Block
Old Jan 21, 2007 | 01:59 PM
JDM_EK4_Coupe's Avatar
(banned)
Default B16B head on B16a SiR II Block
Ok, I am going to swap a B16B Head onto an B16a SiR II block. Now I understand the head is OBD II and the Block is OBD I. Is this a straight bolt on procedure or is there any other things I should be aware of? Also, I heard that when you do this you lose compression, is this true?
Old Jan 21, 2007 | 02:01 PM
BlueIntegraBoy's Avatar
Default Re: B16B head on B16a SiR II Block (JDM_EK4_Coupe)
B16B = B16A
Heads are the same cast
Old Jan 21, 2007 | 02:11 PM
(banned)
Default Re: B16B head on B16a SiR II Block (BlueIntegraBoy)
Ok, would I be able to use my old intake manifold and distributor? Or would I have to go with OBD II?
Old Jan 21, 2007 | 02:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Ok, would I be able to use my old intake manifold and distributor? Or would I have to go with OBD II?</TD></TR></TABLE>
Yes and Yes.
Do you just have the B16A shortblock?
Old Jan 21, 2007 | 02:20 PM
(banned)
Yes, but its temporary. I have a 2.0 L type R block in the works. Will it yiels any performance on the B16a block though?
Old Jan 21, 2007 | 02:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but its temporary. I have a 2.0 L type R block in the works. Will it yiels any performance on the B16a block though?</TD></TR></TABLE>
Unless it came with the CTR cams, not really. There's slight porting and polishing...
Old Jan 21, 2007 | 02:28 PM
(banned)
9honda5civic
Sep 10, 2012 07:51 AM
xtokex
Oct 5, 2007 11:10 PM
Jdmb16sir2
10
Apr 10, 2007 06:46 PM
91hatchcivic
Aug 26, 2002 08:48 AM
BLKCRX
May 31, 2002 08:47 PM
