need help with my head (b16)
Old Jan 21, 2007 | 09:15 AM
nexgen91's Avatar
Default How Do I Take This Apart????????
1. how do I get the camshaft holders off??
2. how do I get the cam gears off (no special tools)??
3. how do I get the rubber plug behind the vtec solinoid off??
4. do I need to try to keep everything TDC??
Thanks
Modified by nexgen91 at 6:28 PM 1/21/2007
Old Jan 21, 2007 | 09:27 AM
nexgen91's Avatar
Default Re: How Do I Take This Apart???????? (nexgen91)
oh forgot to mention I need to know this for swaping LMAs
Old Jan 21, 2007 | 09:54 AM
nexgen91's Avatar
anyone that can help me out????
Old Jan 21, 2007 | 10:12 AM
Educator's Avatar
Bring the motor to TDC.
Mark with a sharpie on the timing belt the position of the cam gears.
Before removing the distributor, mark the position with a sharpie where the top bolt is.
Starting in the middle, partly loosen the cam caps. Do not remove the cam gears from the cams.
Remove the 12mm and 10 mm bolts from the cam caps, then lift the cams from the head. Put EVERYTHING in order, where it should be, on a clean towel or piece of cardboard. You may need a soft mallet to work the cam caps off of the head.
You should be able to remove the LMA's from the head with a magnet.
Old Jan 21, 2007 | 10:19 AM
nexgen91's Avatar
Default Re: How Do I Take This Apart???????? (Educator)
ok, thanks for your help.
civic-one
Nov 11, 2013 10:34 AM
vanny_david
Jan 9, 2010 06:13 AM
Nigel379
Jul 23, 2007 01:32 AM
rough_draft
Mar 26, 2005 05:32 PM
trulyshavedintegra
Mar 24, 2005 04:16 PM
