Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Benefits of lighter motor parts..?
Old Jan 21, 2007 | 08:45 AM
Demonis's Avatar
Default Benefits of lighter motor parts..?
What is the overall advantage of lighter pulleys and flywheels ect.. Just weight reduction or does it actually create less resistance on the motor IE more power makes it to the ground?
Old Jan 21, 2007 | 09:23 AM
projectprelude's Avatar
i have seen dyno results that show that the pullys do wont..but only usually frees up a few hp 2 or 3 from what ive seen.i may be wrong but i think im close and for the lightweight flywheels from what i understand they allow your rpms to clim faster...?not sure of other benifits..
Old Jan 21, 2007 | 10:07 AM
elohel's Avatar
Default Re: Benefits of lighter motor parts..? (Demonis)
A light flywheel allows it to spin more quicker than a heavier one, since it's lighter, which in turn lets you rev up quicker.
Old Jan 21, 2007 | 10:12 AM
24boosted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">Just weight reduction or does it actually create less resistance on the motor IE more power makes it to the ground?</TD></TR></TABLE>
Pretty much answered your own question. Same principal as having heavy wheels vs light weight wheels. Less parasitic loss on the motor with weight reduction benefits. Helps the motor rev more freely.
Old Jan 21, 2007 | 10:54 AM
Demonis's Avatar
So it sort of does both then? Lightens the car and helps it in rotation by creating less weight drag?
Old Jan 21, 2007 | 11:12 AM
Blue Hybrid's Avatar
lighter flywheel allows the motor to accellerate faster, good for racing applications. But because they are light, the have less inertia and kenetic energy. Because of this, lighter components hurt gas mileage because there isnt enough weight to keep components spinning.
Modified by gold EF at 6:08 AM 1/22/2007
Old Jan 22, 2007 | 03:17 AM
RICO_'s Avatar
NO MERCY!
Default Re: (projectprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectprelude &raquo;</TD></TR><TR><TD CLASS="quote">i have seen dyno results that show that the pullys do wont..but only usually frees up a few hp 2 or 3 from what ive seen</TD></TR></TABLE>
The power created by changing out pulleys depends on the engine setup. If you're just changing them out on a stock motor you probably won't see as much gains as you would on a supercharged motor.
d357r0y
Apr 28, 2004 10:03 AM
Scean
Mar 23, 2004 10:37 AM
Solracer
Mar 11, 2004 07:26 AM
TTWS6.
Sep 9, 2003 08:03 AM
93si
Jul 7, 2003 07:23 AM
