IACV cleaning didnt work!!
Old Jan 21, 2007 | 07:15 AM
krytykalintentions's Avatar
Default IACV cleaning didnt work!!
so i took of my IACV and clean it out but, my car is still surgin rapidly from 1500 rpms to 5 or 400 rpms... when i took it of it didnt have the round gasket on it but i took it of my old head that had a manifold on it to put on my skunk 2 manifold on my type r head.... but it didnt have the gasket b4 and it worked fine.... this whole problem started after i put my new head on... any1 got any other ideas???
Old Jan 21, 2007 | 08:17 AM
JasonST's Avatar
Default Re: IACV cleaning didnt work!! (krytykalintentions)
Try cleaning ur FITV, do a search if u want to know how to clean it. It's the fast idle thermo valve located on the throttle body.
Old Jan 21, 2007 | 09:10 AM
95 integra's Avatar
Default Re: IACV cleaning didnt work!! (JasonST)
Vacuum leak or wiring issue. Cover the 2 holes on the throttle body and if the car doesn't die then its a vacuum leak. Unplug the IACV and see where the baseline idle is set.
Old Jan 21, 2007 | 09:37 AM
Brick Top's Avatar
Default Re: IACV cleaning didnt work!! (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Vacuum leak or wiring issue. Cover the 2 holes on the throttle body and if the car doesn't die then its a vacuum leak. Unplug the IACV and see where the baseline idle is set. </TD></TR></TABLE>
Old Jan 22, 2007 | 05:19 PM
Default Re: IACV cleaning didnt work!! (brick top)
ill try it and let ya know asap!!! thanx
Old Jan 22, 2007 | 05:46 PM
MRXMUFFIN's Avatar
I had loads of idle surging last year when put in a jrsc. My tuner tried configing my hondata, but what really worked was unscrewing the idle screw on the throttle body. He unscrewed it A LOT (not just a couple turns, ALOT of turns) but he told me if the idle started going back to surging, then its time for a new IACV. So, it fixed the problem and my idle didnt fall below 1K rpms, until recently. Now im biting the bullet and getting a new IACV, should be in this week, ill reply how my idle is after.
Old Jan 22, 2007 | 06:19 PM
Default Re: IACV cleaning didnt work!! (MRXMUFFIN)
sounds good let me no the results!!!
Old Jan 22, 2007 | 07:20 PM
95 integra's Avatar
btw, kill the bold.
Old Jan 23, 2007 | 07:30 AM
jonshonda's Avatar
Community Builder
Try the IACV, if that doesn't work, punch your car right in the taint
thewrai6th
Sep 13, 2011 05:19 PM
feriotypeR
Oct 10, 2009 03:58 AM
the_dxB16
Mar 13, 2008 10:47 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
