Fuel, air, and ECU
Ok so i've got most of my motor work done but now i have another question.....fuel. I want to put a fuel rail and bigger injectors on the car but didn't know how big to go with the injectors. Before i get into that, i'll give you some back ground on the motor to help. Its a bored out block to .25 with p30 pistons, micropolished crank, resised big end of rods, stage one cam shafts, valve springs, 4-2-1 header, skunk2 cam gears, skunk2 intake manifold, and polished exhaust side of the head. The motor will run around 11:1 compression. So, i was thinkin of injectors around 300-350cc but than came the problem with the throttle body....how big should that be?? 68? 70? and to top that all off what should i do about the computer so that the air to fuel ratio is mapped out of whack???? I need some help cause i'm all out of ideas
!!! Thanks guys
!!! Thanks guys
you'll need to convert to obd1 if you're already not. have your ecu socketed, chipped, and tuned with whatever ems your tuner prefers. a fuel rail wouldnt be needed but 310cc injectors should be adequate.
ncVTEC1313
Aug 24, 2008 06:34 PM
b16nonoy
Mar 20, 2007 09:22 AM
