Z6 intake manifold and TB on a D16A6
Old May 15, 2002 | 10:51 PM
crx_91si's Avatar
Default Z6 intake manifold and TB on a D16A6
sup every1. Here's the deal, I'm looking to build a nice D16A6 n/a set-up. So far i've got the usual bolt-ons + a chipped ECU.
question is, I have access to a blown D16Z6 motor and was wondering if anyone knew if the Z6 intake manifold and TB fits the D16A6. And if it does, will it increase performance for my CRX if swapped on?
mike
Old May 15, 2002 | 10:59 PM
Urban Business
Guest
Posts: n/a
Default Re: Z6 intake manifold and TB on a D16A6 (crx_91si)
i believe it does bolt on. it flows better than the stock d16a6 manifold. tb is slightly larger i could be wrong. it'll fit tho.
Old May 16, 2002 | 12:30 AM
ImportHatch's Avatar
Default Re: Z6 intake manifold and TB on a D16A6 (TorteX)
Yeah I dont see why it wouldnt fit...
Yager-
Old May 16, 2002 | 04:56 AM
markedOO1's Avatar
..it'll bolt up fine..you'll just have to extend a sensor or two...like the MAP sensor is on the tb, etc...
Old May 16, 2002 | 05:39 AM
zcivicz's Avatar
you will also have to port match the head cuz the Z6 runners have larger diameters than the A6. if you don't do this, you might as well stick with the A6 intake manifold. also you can't use the OBD1 injectors, use the stock Si injectors and extend some wires (as mentioned)
Old May 16, 2002 | 05:54 AM
4gvtec's Avatar
easy swap.just extend the map sensor wires.and get rid of the fast idle control selonoid.its better than the a6 but not as good as the y8.another plus is that you can go aem fuel rail and fuel pressure regulater or dc or what ever.no one makes anything for the a6 intake.
Old May 16, 2002 | 06:19 AM
KS-R's Avatar
Default Re: Z6 intake manifold and TB on a D16A6 (4gvtec)
If you can.. you'll want to go with the Y8 intake manifold cause it flows better... Another thing is that the Y8 and the A6 have the same amount of collant lines, but the Z6.. you'll end up having to plug one line.. not cool.
Old May 16, 2002 | 06:55 AM
4gvtec's Avatar
Default Re: Z6 intake manifold and TB on a D16A6 (KS-R)
if you live where its hot dont use you throttle body coolant lines.
think about it 200 degrees going through you tb,no way.
its only used to heat it up it cold *** wheather.
Old May 16, 2002 | 07:45 AM
AudioXtremes's Avatar
is the head good? if so just do the whole head swap! mini me baby!
Old May 16, 2002 | 11:41 AM
OneScarySOHC's Avatar
Default Re: Z6 intake manifold and TB on a D16A6 (AudioXtremes)
to set the record straight, obd1 injectors DO work
and you said yuo had access to a z6 motor...just do the whole swap...you'll be alot happier
puertoricanboy90
35
Dec 4, 2008 07:48 AM
haroldthefly91crx
Nov 30, 2006 06:05 PM
Manny86
Oct 29, 2006 07:32 PM
4DRmafia
19
Mar 4, 2006 06:11 PM
SOUTHCREX
Nov 18, 2002 06:03 PM
