d16z6 crx, crank pulley keeps falling off.
Old Jan 20, 2007 | 09:21 PM
wfocrx's Avatar
Default d16z6 crx, crank pulley keeps falling off.
I have had my d16z6 swap for a couple months and ~2000 or so miles. Last week I was driving it and the car started shaking violentl for a little bit and then the battery light went off. I pulled over and saw the crank pulley hanging on for dear life and the accessory alternator belt missing. I towed it home and got a new belt and crank pulley key piece and then I drove it for a ~5-10 miles and then the same thing happened again. wtf?
Old Jan 20, 2007 | 11:27 PM
redzcstandardhatch's Avatar
something different
Default Re: d16z6 crx, crank pulley keeps falling off. (wfocrx)
try getting a new crank pulley..most likely the pulley is worn down inside, making it too big.
hopefully the crank snout is ok.
LOCTITE the crap out of the new one..put it everywhere, IMO..that stuff works wonders..let it dry too. might make it work. it'll be tougher to get off next time, but it might save ya
Old Jan 22, 2007 | 09:26 PM
wfocrx's Avatar
where should I get a new crank pulley from? are the ebay ones ok? or should I get an oem one?
Old Jan 23, 2007 | 12:15 AM
CarAudioPro's Avatar
Default Re: (wfocrx)
oem
Old Jan 23, 2007 | 12:40 AM
MachinaInfernus's Avatar
Default Re: (CarAudioPro)
could the crank pully be off balance..i've heard that happening with aluminum ones.
Old Jan 23, 2007 | 12:55 AM
djphonics's Avatar
Default Re: d16z6 crx, crank pulley keeps falling off. (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">
LOCTITE the crap out of the new one..put it everywhere, IMO..that stuff works wonders..let it dry too. might make it work. it'll be tougher to get off next time, but it might save ya</TD></TR></TABLE>
If you're gonna use Loctite, try this stuff (Loctite Sleeve Retainer):
http://www.amazon.com/gp/offer...ew%2F
It's more appropriate for the application, and let me tell you, this **** is hardcore for this sort of thing.
Old Jan 23, 2007 | 04:56 AM
DaX's Avatar
DaX
Loved
Community Favorite
Are you applying enough torque to the crank pulley bolt? You should really invest in a crank pulley holder tool to allow you to properly torque the bolt.
Old Jan 23, 2007 | 05:07 AM
VegaS10's Avatar
A friend of mine had the same problem with his B16. The previous shop did'nt tighten it all the way. The slot where the key went was twice as wide as it should have ben due to it just sitting there and moving. No matter what we did, the key would just "float" around in there instead of "sitting still". He sold the car before we could fix the issue.
danteisme
Mar 27, 2016 03:15 AM
dtk132
Nov 5, 2010 02:48 PM
longlivekel1
19
Apr 6, 2010 05:59 PM
rogue420
Jul 20, 2008 06:55 PM
