D15 Surging need help
Old Jan 20, 2007 | 09:04 PM
pimpami333's Avatar
Default D15 Surging need help
My D15 in my civic is surging really bad.. it idles jumping between 1000 and 2000.. and it keeps surging i have checked all the vac lines n the egr valve.... n the plugs n they are not switched.... please help.. thanx
Old Jan 20, 2007 | 09:07 PM
platinumx6's Avatar
Default Re: D15 Surging need help (pimpami333)
http://www.ef-honda.com/ben/Badidle.php
mines doing that and im 90% sure i need a new IACV
ps: it says EF but its the same ****
Old Jan 21, 2007 | 06:27 AM
pimpami333's Avatar
Default Re: D15 Surging need help (platinumx6)
thank you.. are you sure that is the problem.... because i was able to drive it last night and when i drove it the only time that it tended to surge was when i was at a stop.. when i accelerated it did not surge or anything... i had replaced many things on the intake manifold and all the vacuum lines... thank you..
Old Jan 21, 2007 | 06:30 AM
platinumx6's Avatar
yes my car runs smooth through the rpm range just at idle. Clean your IACV, FTIV and TB(there is a archived thread on here i used) That fixed most problems, the IACV is very easy to clean, its 2 12mmbolts and remove to hoses with clamps...The rest is easy to now that i think about it.
I cleaned mine and i got a new problem that rarely occured before. Once my engine is warm it surges in Park and N, and when i coast to a stop occasionaly. I unplug my IACV and it stops and idles beautifuly; ie bad iac valve
Old Feb 28, 2010 | 07:50 PM
dfollis's Avatar
what is a FTIV
Old Mar 11, 2010 | 04:55 PM
95civicdb's Avatar
Also have you checked the coolant level? if it gets low it will idle like that. Also you see any smoke out the exhuast? Check your T-stat also.
b17hybrid
Mar 18, 2019 09:07 AM
jb0705
10
Aug 30, 2009 02:13 PM
Boostn B20
Oct 30, 2008 07:04 PM
jdmdseries
Jan 23, 2008 05:52 PM
red_crx
Dec 5, 2004 01:26 PM
