fuel cut switch
Old Jan 20, 2007 | 07:26 PM
19992civichatch's Avatar
Default fuel cut switch
i saw a thing i nthe ef forum about a fuel cut of switch is that the same for the eg
Old Jan 20, 2007 | 07:33 PM
hondapwr's Avatar
Default Re: fuel cut switch (19992civichatch)
No clue what you're talking about, but you can buy a simple switch at an autoparts store and easily splice it into the wiring for the fuel pump under your rear seats..
Old Jan 20, 2007 | 07:35 PM
do i have to power the switch from the fuse box or i dont have to power it at all?
Old Jan 20, 2007 | 07:41 PM
bpr0422's Avatar
see the red link in the upper right hand corner???
click it..
this is discussed over and over again in the audio/video/security forum
all it is a 30amp switch interrupting a certain wire, you can go even more advance with a relay
have fun searching ^^
Old Jan 20, 2007 | 07:51 PM
yea i sreached and only saw the one for the ef and wanted to no if it was the same
Old Jan 20, 2007 | 09:05 PM
platinumx6's Avatar
Default Re: (19992civichatch)
go to audio video security section and go to the sticky, its in there.
Old Jan 20, 2007 | 09:10 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (platinumx6)
GAH Ignorance.
It's common that most people fail to hit the "Archived" button when they search.
Old Jan 21, 2007 | 05:34 AM
aeboync's Avatar
http://www.courtlukens.com/Tech/cutoff_switch.htm
here you go man. You gotta seach a lil harder next time. Sometimes people on here are real asses. Dont really want to help someone. Just put 'em down.
Old Jan 21, 2007 | 02:03 PM
thank you
Old Jan 21, 2007 | 02:07 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch &raquo;</TD></TR><TR><TD CLASS="quote">do i have to power the switch from the fuse box or i dont have to power it at all?</TD></TR></TABLE>
No, just put it between the pump and the ground, or the main relay and the fuel pump (power).
Either way, the switch breaks the connection and keeps the fuel pump from working.
Old Jan 21, 2007 | 02:14 PM
i was reading some thing about fuel cut off swithces and it said u could use the ground but it can mess up the pump is thsi true
Old Jan 21, 2007 | 05:09 PM
Ek Forever y0!
Why would grounding a switch expletive up the pump?
https://honda-tech.com/zerothread/1194912
LS_VTECteggy
Oct 18, 2009 09:27 PM
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
JDM.Type-r
Aug 27, 2007 11:19 AM
hatchinprogress
Aug 27, 2004 05:09 PM
Lynx
May 16, 2002 05:17 PM
