Quick, HELP!. crower stg 3 cams
Old Jan 20, 2007 | 05:10 PM
kdt3's Avatar
Default Quick, HELP!. crower stg 3 cams
i need to know the valve clearance for the h22 stage 3 all motor cams...
Old Jan 20, 2007 | 05:37 PM
98vtec's Avatar
moderator emeritus
Default Re: Quick, HELP!. crower stg 3 cams (kdt3)
do you have a cam spec card?
Old Jan 20, 2007 | 05:42 PM
kdt3's Avatar
no, all i have are the cams
Old Jan 20, 2007 | 05:43 PM
98vtec's Avatar
moderator emeritus
Default Re: (kdt3)
call or email crower. done.
Old Jan 20, 2007 | 05:50 PM
kdt3's Avatar
i tried all that,everything closed. i should have posted i needed this info by 7am or ill miss the car/race show...someone that has the info please reply.
Old Jan 20, 2007 | 06:03 PM
PrecisionH23a's Avatar
The specs will pull a premium for race wars.
Old Jan 20, 2007 | 06:29 PM
kdt3's Avatar
the specs is what keeping me from finishing my car in time for the show
Old Jan 20, 2007 | 06:32 PM
Default Re: (kdt3)
Are you wanting valve lash?
If it helps... the crower turbo cams are .006 Int and .008 Ex.
Old Jan 20, 2007 | 06:40 PM
98vtec's Avatar
moderator emeritus
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Are you wanting valve lash?
If it helps... the crower turbo cams are .006 Int and .008 Ex.</TD></TR></TABLE>
just like stock. Would there be any reason that the clearance would deviate from stock in the first place?
Old Jan 20, 2007 | 06:43 PM
DrivinVtec's Avatar
Default Re: (98vtec)
are you usen a stock valve train?
Old Jan 20, 2007 | 06:48 PM
kdt3's Avatar
yup im using stock valvetrain so that way the stage 3 cams which are very aggressive will blow my head up..a guy on PO told me the specs were .006 int and .008 ext. now im confused with your post precisionh23a
Old Jan 20, 2007 | 06:51 PM
98vtec's Avatar
moderator emeritus
Default Re: (kdt3)
why are you confused?
DrivinVtec's Avatar
stock VT?? WTF. good luck with that.
Old Jan 20, 2007 | 06:54 PM
98vtec's Avatar
moderator emeritus
Default Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">stock VT?? WTF. good luck with that. </TD></TR></TABLE>
think outside the box and reread what he posted george.
Old Jan 20, 2007 | 06:56 PM
mgags7's Avatar
precision was joking, then he told you what to set the valve lash to.
zero out your cam gears.
/thread - until you hit the dyno
Old Jan 20, 2007 | 07:32 PM
Default Re: (bb4ever)
/thread until he buys retainers and springs.
Old Jan 20, 2007 | 07:36 PM
DrivinVtec's Avatar
Old Jan 20, 2007 | 10:10 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">/thread until he buys retainers and springs. </TD></TR></TABLE>
/you until you realize he was kidding
lol....at least I think he was kidding hhaa
Old Jan 20, 2007 | 11:00 PM
madcatz's Avatar
so did he make it to race wars?
I hear that Johny Chan is not one to be messed with
Old Jan 20, 2007 | 11:11 PM
98vtec's Avatar
moderator emeritus
Default Re: (madcatz)
tran*
Old Jan 20, 2007 | 11:19 PM
Johny must be Jackie's brother?
revhardallday
Nov 26, 2008 03:08 PM
adam00
Aug 13, 2008 05:24 AM
slowteg550
Jul 12, 2006 09:47 PM
mugenracer
Mar 13, 2005 09:29 PM
HRED
Mar 16, 2004 11:34 AM
