flooded engine
Old Jan 20, 2007 | 04:56 PM
oakpwr's Avatar
Default flooded engine
Car still wont start. Resoldered the main relay, sounds good. I hear the click and then the fuel pump runs for two seconds. Car still wont start. Replaced the fuel filter. No start.
I pull the plugs and sure enough they are SOAKED with gas. I freaking flooded it bad. It wont start with the pedal to the floor even after letting it sit for fifteen minutes.
I was reading up and it said that once a spark plug is soaked it wont work anymore. Is this true? If I flooded it that badly, do I just replace the plugs and start it again?
Old Jan 20, 2007 | 05:29 PM
Targa250R's Avatar
be professional
Default Re: flooded engine (oakpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oakpwr &raquo;</TD></TR><TR><TD CLASS="quote">I was reading up and it said that once a spark plug is soaked it wont work anymore. Is this true?</TD></TR></TABLE>
No.
You're obviously getting fuel, but have you checked to see if you're getting spark?
Old Jan 20, 2007 | 05:48 PM
oakpwr's Avatar
Default Re: flooded engine (Targa250R)
I'm going to check it in the morning, the lame part is I live alone. The spark plug wires wont reach the ground where I can see them when I start the engine so I cant turn it over and check the plugs. Any other suggestions when I'm doing this by myself?
At the least I've narrowed it down to spark.
Old Jan 20, 2007 | 05:58 PM
Targa250R's Avatar
be professional
Oh, that's a problem. I've always used a buddy to crank the engine while I check for spark.
Old Jan 20, 2007 | 06:00 PM
oakpwr's Avatar
I guess I can bust out a bunch of mirrors, lol.
Keno20
Jan 26, 2009 10:10 PM
lilmisshonda
Jul 2, 2008 09:40 PM
em1_fox
Oct 28, 2007 12:11 PM
Hondaciv95VX
Mar 21, 2007 07:53 PM
nylshatch
Nov 28, 2005 06:29 PM
