air intake installation
Old Jan 20, 2007 | 04:56 PM
pdx_503's Avatar
Default air intake installation
I just recently bought a cold air intake for my 88 hatch. Its a no-brand intake because I had little money to spend. I recieved it recently and dont know how to put it together. Dont have much information about it, so any help would be great.
Old Jan 20, 2007 | 05:55 PM
dr_latino999's Avatar
Default Re: air intake installation (pdx_503)
Um.....wow
Anyways,
1) Remove stock airbox
2) Remove stock airtube
3) Attach really long piece of CAI to throttle body
4) Use silicon coupler and two clamps
5) Attach filter to remaining piece using one clamp
6) Remove fender well lining near bumper
7) Find hole left by stock airbox, insert CAI extension into hole.
8) Attach the two pieces using silicon coupler, two clamps.
9) Reattach fender well lining.
Old Jan 20, 2007 | 06:37 PM
janz3n's Avatar
Default Re: air intake installation (dr_latino999)
you may have to take the bumper off to get that air box behind the wheel well out.
Old Jan 20, 2007 | 07:57 PM
oakpwr's Avatar
Default Re: air intake installation (janz3n)
is it a cold air? mine was so low that i hit a bump on the freeway and the filter got stuck in the wheel well. it was bolted on right but that flex tube sucked the big one. I ended up using some wire to tie it in place down below.
if you are still stuck, post a pix of it and we'll piece it together, its simple
Old Jan 20, 2007 | 08:42 PM
oodie's Avatar
Default Re: air intake installation (oakpwr)
Its not that hard to figure out lets see clamps and pipe fiter put them together
Old Jan 22, 2007 | 05:56 PM
pdx_503's Avatar
Default Re: air intake installation (oodie)
Thanks for all the feedback. Yeah the only problem I have is with all the fittings. Just not sure what goes where. I will try to post some pics of it.
Old Jan 23, 2007 | 04:27 PM
pdx_503's Avatar
So I successfully installed my cold air intake without any instructions and without any knowledge whatsoever. I was told I had to take off the bumper in order to pull out the air box next to the fender wall. I did it by going through the turn signal hole, it was a bitch though.
Old Jan 23, 2007 | 04:50 PM
nk2k2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdx_503 &raquo;</TD></TR><TR><TD CLASS="quote">So I successfully installed my cold air intake without any instructions and without any knowledge whatsoever. I was told I had to take off the bumper in order to pull out the air box next to the fender wall. I did it by going through the turn signal hole, it was a bitch though.</TD></TR></TABLE>
good for you *no sarcasm. hope fully you can do more mods to you car on your own and that way you will understand how things function better mechanically.
Old Jan 23, 2007 | 04:53 PM
89efDUSTY's Avatar
Default Re: air intake installation (4g4d)
Cable ties no risk and less noise
Old Jan 23, 2007 | 05:03 PM
Mr. Giggles's Avatar
good for you
I remember when i did my first one, couple years ago
Old Jan 23, 2007 | 07:10 PM
janz3n's Avatar
Default Re: air intake installation (SmrCRX)
oh man.. shoulda just took both turn signal lights out unbolted the four bolts and the screws in the wheel well and took the bumper off.. woulda took alot less time
thajray
Sep 4, 2006 12:02 PM
b18c-1
Jul 6, 2005 08:50 PM
Swift1
Apr 7, 2005 10:01 AM
civic_on_13s
Jul 28, 2003 05:25 PM
muskrat
Aug 20, 2002 08:21 AM
