looking for traction. Wider wheel in front ok?
Old Jan 20, 2007 | 04:27 PM
DougieStyle's Avatar
Default looking for traction. Wider wheel in front ok?
I know this a kind of the wrong forum but i want to know if it would be ok for me to run 15x7 up front with 225 bfg drs and 15x6 in the back with a 195 tire. This is not my DD but is drivin on the street.
Thanks, Doug
Old Jan 20, 2007 | 04:54 PM
spoolin_teg's Avatar
Default Re: looking for traction. Wider wheel in front ok? (DougieStyle)
you can do that
Old Jan 20, 2007 | 05:00 PM
RedEj8's Avatar
Default Re: looking for traction. Wider wheel in front ok? (spoolin_teg)
Do it..But get full slicks instead of drag radials..Unless you want to drive it on the street like that. Also, do you have a traction bar and LSD?
Old Jan 20, 2007 | 05:23 PM
i have lsd but its not enough so im going with a traction bar omni drag coilovers and probally gona do these 225 bfgs in front.
Old Jan 20, 2007 | 05:34 PM
RedEj8's Avatar
Default Re: (DougieStyle)
yea. Well if you are just planning to race it at the track than go with slicks but if your racing on the street then yea drag radials r ok.
Old Jan 20, 2007 | 05:42 PM
OnlyHJC's Avatar
do it. or get 225's in the back too!
Old Jan 20, 2007 | 11:16 PM
sgtroseberry's Avatar
Default Re: (OnlyHJC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnlyHJC &raquo;</TD></TR><TR><TD CLASS="quote">do it. or get 225's in the back too!</TD></TR></TABLE>
Old Jan 20, 2007 | 11:58 PM
komat's Avatar
Default Re: (sgtroseberry)
if you jack your car up higher. you can run 235/60/15
Old Jan 21, 2007 | 12:27 AM
RedR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgtroseberry &raquo;</TD></TR><TR><TD CLASS="quote">
lmao
Old Jan 21, 2007 | 06:34 AM
HiProfile's Avatar
Technically speaking, it could help a tad for the 60ft. The higher the rear end (as well as higher spring rate) lessens weight transfer off the front, which helps. Why is it you never see a seasoned racer piloting a car with a slammed ***-end?
jdm-gsr
Jun 1, 2009 10:20 AM
TA Performance
Jun 29, 2007 01:51 PM
97grnrs
Apr 28, 2006 04:17 PM
sporkcrx
Mar 28, 2005 08:23 PM
Soled Out
Jun 24, 2003 08:48 PM
