after market tach???
Guest
Posts: n/a
connect it to the blue wire on the dizzy
there will be a circular 2 wire connector with a blue wire and a black w/ yellow stripe. either splice into blue wire of attach your wire into the blue side of the connector.
just unscrew where the the blue wire hooks to the terminal on the coil. then splice a terminal onto the wire for the tach and screw them both back down. it will make a lot more sense when you see what i am talkign about.
NeedACivic
May 7, 2003 01:57 PM
