LS: When setting the timing...
Old Jan 20, 2007 | 03:50 PM
JokerTypeR's Avatar
Default LS: When setting the timing...
What's the order...I loosened up and got the belt off, lined up the crank pulley (white mark/TDC)...then what?
Do I set the exhaust pulley to time or intake pulley first, and which side is supposed to have the slack when doing this?
Old Jan 20, 2007 | 06:01 PM
JokerTypeR's Avatar
Intake first, thanks.
Old Jan 20, 2007 | 06:17 PM
youdontknowmeeither's Avatar
Default Re: LS: When setting the timing... (JokerTypeR)
you have to leave the tensioner loose and rotate the engine conter clockwise a few revolutions and put the cam gears 3 teeth past tdc and tighten the tensioner.. just in case you didn't know...
Modified by zachlange at 9:11 AM 1/21/2007
Old Jan 21, 2007 | 04:18 AM
Sam92Teg's Avatar
Default Re: LS: When setting the timing... (zachlange)
Rotate engine counter clockwise.
Old Jan 21, 2007 | 04:36 AM
rebelteggy's Avatar
Default Re: LS: When setting the timing... (Sam92Teg)
once u set up ur cam timing up both intake and exhaust and have ur main crank set to TDC. u keep ur tensioner loose and then hold the timing belt on ur cam sprockets then u turn ur crank bolt counter clock wise about two to three times. u should notice the belt gets tighter. then u tighten ur tensioner. u should get a repair manuel from ur local autozone, it would tell u the same thing and save u some time.
Old Jan 21, 2007 | 08:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Rotate engine counter clockwise.</TD></TR></TABLE>
oh crap, i had it right in my head at least...
austinramsay
Jul 5, 2014 12:42 PM
wk9k
Mar 13, 2012 05:45 PM
i-spit-hotfire
May 21, 2009 02:51 PM
HBK
Sep 1, 2005 09:37 AM
Jonathan_ED3
Apr 12, 2003 02:55 PM
