help with turbo vacuum lines
i need help running the vacuum lines for an integra with a drag turbo kit. as of right now i tapped into my IM with 1 vacuum going to the bov and 1 going to the wastegate with a manual boost controller. Theres also a fitting on my turbo housing, am i suppose to run the vacuum line from the wastegate to the turbo housing or should i run 1 vacuum line to the IM and 1 to the turbo off the wastegate?
You can either run the line from the turbo to the wastegate or from a vac. source to the wastegate.The side port of the wastegate to be exact, leave the top port open.
kaj
Sep 5, 2004 05:22 PM
