95 Accord EX V6 - ABS light is on, but with no code..?
Old Jan 20, 2007 | 02:57 PM
mstewar's Avatar
Default 95 Accord EX V6 - ABS light is on, but with no code..?
The SRS light is currently on (airbags and module are out of the car at the moment). I did not think they are related, so I jumped the service connector and got no code, the light just stayed on. Could having the SRS light on actually be forcing the ABS light to be on as well somehow?
Thanks!
Old Jan 20, 2007 | 05:05 PM
hondadude's Avatar
Default Re: 95 Accord EX V6 - ABS light is on, but with no code..? (mstewar)
have you tried doing a reset by pulling the fuses in the underhood ABS fusepanel?
Old Jan 21, 2007 | 05:38 AM
Ross 2.0's Avatar
In a Junkyard near you.
since the srs unit is out that explains the light, but the ABS light probably isn't related.
Use the procedure that I just posted (it's probably in the accord FAQ) and get the abs code
Old Jan 21, 2007 | 08:44 AM
JDM_DC4_Fanatic's Avatar
sometimes ABS sensors get dirty, I know its a common problem on alot of GM's and some acura's. I'm new to accords, but I would check your wheel bearings for excessive play, since the sensor is attatched to the bearing. also, clean the sensors, and check your brake fluid level.
Old Jan 22, 2007 | 09:04 AM
mstewar's Avatar
i appreciate everyone's help.. turns out, the ABS light can be thrown by the power mirror fuse being blown, which it was. never would've guessed it, but that's what the cause was..
00n0908
Sep 11, 2016 09:39 AM
ClarkS40
Mar 21, 2009 11:59 PM
sneakerfern
Feb 20, 2007 04:37 PM
M2nR
Aug 24, 2004 07:49 AM
