obd2 question is there a security system that cuts the injectors off............
If you're talking about the immobilizer feature of certain OBD-2b ECUs, you don't "reset it". The feature has to be removed, and that's not a process that should be discussed on a public forum.
i have two keys factory keys from the dealership when i bought the car brand new in 01 bro....and the imobilizer is not actived i found out but i would like to take it off because the injectors are not opening up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cviccoupe »</TD></TR><TR><TD CLASS="quote">y not</TD></TR></TABLE>
Because thieves can read these forums just as easily as legitimate members.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cviccoupe »</TD></TR><TR><TD CLASS="quote">i have two keys factory keys from the dealership when i bought the car brand new in 01 bro....and the imobilizer is not actived i found out but i would like to take it off because the injectors are not opening up...</TD></TR></TABLE>
It is functioning, assuming the ECU hasn't been modified at all. The immobilizer is a passive system that requires no action on the part of the owner in order to function. If you tried putting the ECU in a different car without any of the necessary immobilizer wiring or key reader, it's not going to work. As I said, there are ways to remove the immobilizer. Search the archives for "remove immobilizer" and you'll find a few threads with information that should help you out.
my boy is bringing me one tonite from his shop...ur saying its not going to work??????i have a bigger problem.i think the immolizer is good because if it waz bad it key symbol on the cluster would flash when trying to start and if it doesnt the imobilizer is work perfectly....now i dont have a ground on my injectors with the key on.....what could be the problem
Please elaborate on your entire setup. What car the ECU is from, what car the is ECU going in, modifications, etc. I'm getting confused about what exactly you're trying to accomplish.
SoyMilk
12
May 27, 2007 04:37 PM
