how can you tell what b-series tranny you own?
Old Jan 20, 2007 | 12:33 PM
dem0nk1d's Avatar
Default how can you tell what b-series tranny you own?
is there any indication on how to tell what type b-series tranny you own? I bought a ued tranny I need to make sure it's a gsr, that's what they told me.
Old Jan 20, 2007 | 12:36 PM
pdiggitydogg's Avatar
Since LS and GSR tranny both use S80, the only way that I know, is to open it up and count the teeth on the gears or look at the differential
Old Jan 20, 2007 | 12:37 PM
hondachris1994's Avatar
there should b a sticker that has the tranny code and then some numbers after it
EGwhat!!!'s Avatar
Default Re: (pdiggitydogg)
In some cases trying to ID a B-series tranny is not always possible from it's external markings. So how can you tell?
This is what i have found to be the easiest method of doing so.
First you have to start off by taking the outer casing off. Fortunetly we already have a how to on that subject thanks to Plan B: How to: Take Apart a Transmission
Now that you have it apart. You can either go a step further and remove all the internals to be able to count every gear, or just get a tooth count on the final drive gear, it's opposing gear located on the counter shaft, and the upper most gears on both the counter and main shafts to calculate the transmissions 5th and final drive gear ratios.
Once you have counted how many teeth are on each gear, you need to divide the number of teeth on the counter shaft, by the number of teeth on the main shaft to find the gear ratio. I'll give you an example using the transmission pictured. **
There are 25 teeth on the upper most counter shaft gear and 35 teeth on it's opposing gear located on the main shaft. If you divide 25 into 35, you come out with a .7142857 (.714) ratio, which is the 94+ LS transmission's 5th gear ratio.
Now using the same method, you can find the FD ratio by counting the teeth of the final drive gear, and then dividing that by the number of teeth of it's opposing gear located on the counter shaft, which would be 64 / 15 = 4.26666666 (4.266). The 94+ LS transmission's final drive ratio.
Here is a list of B series tranny gear ratios for reference purposes:
The information in this chart is for reference only, and may not be 100% accurate in all cases.
or you can use this:
http://www.bseries.net/html/specs/btrannyspecs.php
Well that's about all there is to it. Hope this is helpful to some of you...
00trbocoupe
Apr 21, 2009 02:35 PM
Stingray96
Aug 12, 2006 04:30 AM
jdmcraig
Feb 17, 2005 10:49 PM
nicknasty
Jun 22, 2003 03:30 PM
Mr Hybrid
Mar 25, 2003 02:57 PM
