trust washers
Old Jan 20, 2007 | 11:24 AM
WD40's Avatar
Default trust washers
i have a set of thrust washers one is acl and one is king what ones should i use and will the acl one make my crank walk. i was told they do. its for a b16 all the info is help full. direct me in the right way please
Old Jan 20, 2007 | 11:28 AM
WD40's Avatar
Default Re: trust washers (locoridr)
also have a set of oem ones
Old Jan 20, 2007 | 11:42 AM
Combustion Contraption's Avatar
1. Place OEM washers in block
2. Place crankshaft in block
3. Mesaure crankshaft endplay
4. If endplay is in spec. use OEM washers, if not, repeat steps 1-3 with ACL washers in place.
Old Jan 20, 2007 | 11:54 AM
98vtec's Avatar
moderator emeritus
Default Re: (Combustion Contraption)
w3rd 2 ur motha
Old Jan 20, 2007 | 12:23 PM
b19coupe's Avatar
I am not aware of any issues with ACL thrust washers.
Old Jan 20, 2007 | 02:13 PM
WD40's Avatar
ok sounds dume but what are the specs and tq #s for the crank stuff like that would help also is king bearings any good
Old Jan 20, 2007 | 02:17 PM
91SiZ6's Avatar
Yes, that is extremely dumb. Stop touching your engine until you buy a repair manual.
Old Jan 20, 2007 | 02:25 PM
WD40's Avatar
ok sir
Old Jan 20, 2007 | 05:27 PM
RedEj8's Avatar
Default Re: (locoridr)
I have acl thrust washers as well as main and rod bearings..no problems here.
BukakkEK9
Apr 2, 2007 07:38 PM
ilikebigbutts
Jan 22, 2007 07:55 PM
bb4socal
Dec 22, 2006 06:08 PM
CivicSiRracer69
Jul 19, 2004 03:21 PM
