b18c1 engine ?
would jdm itr pistons work on a other wise stock motor. i gotta bore out my block do to a bad spark plug.. and im wondering if i can use jdm itr's pistons on my stock crank and rods.. let me know!!
bore out your block because of a bad plug? how does that happen?
to answer your question, yes you can. but the pistons must match the bore size too.
what well b the result of putting jdm itr pistons ... higher comp i know.. will my tq get higher?? mid range or high? any help would be nice...
well. im hoping to just get alittle more top range w/ the pistons ... and i wanna raise my red line to 8500. w/ stock valvetrain w/ arp rod bolts... which is achievable?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chngeovr99 »</TD></TR><TR><TD CLASS="quote">well. im hoping to just get alittle more top range w/ the pistons ... and i wanna raise my red line to 8500. w/ stock valvetrain w/ arp rod bolts... which is achievable?</TD></TR></TABLE>
you need a better valvetrain and better cams
From: ...and then along comes the fcuking policia, PA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindLess311 »</TD></TR><TR><TD CLASS="quote">if ur boring your motor ull need over size pistons. bore it .020 and get 81.5mm pistons in what ever comp ratio u want</TD></TR></TABLE>
Dont do that ^^^ A .020 bore is for 81.25mm pistons and go with the JDM ITR's, you will be surprised of the c.r. and the CTR are too high
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attentionwhore »</TD></TR><TR><TD CLASS="quote">
Dont do that ^^^ A .020 bore is for 81.25mm pistons and go with the JDM ITR's, you will be surprised of the c.r. and the CTR are too high</TD></TR></TABLE>
Mindless was right.
1"=25.4mm so .010"=.254mm, .020"=.508mm
Mindless was right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chngeovr99 »</TD></TR><TR><TD CLASS="quote">with pr3's... what do i get it bored out to???</TD></TR></TABLE>
It depends on what size piston you buy.
I would take that block to a machine shop first and let them measure how deep the scratches are in the bore. That will determine what size pistons you need.
OK.. Thank you so much for your help guys. i think im just gunna go w/ the ITR pistons.. now i found blox A cams.. u think those would mate together good or bc 3??
