just finished swap, went for test drive.........but having transmision prob.
i just finished a swap and went for a test drive, car started went to push clutch down then all of a sudden tranny was making a loud scratching sound, every time i push in clutch it makes that noise. and it wont let me put it in gear. it just gets louder when i try..what is the prob???
i turned off the car put it in first gear with the clutch dwn i started it up.. no noise then i started to relase clutch then the noise came back????? what is going on? is it the pressure plate? or cluch? or tranny??? please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoNdABaBy27 »</TD></TR><TR><TD CLASS="quote">so you think it could be just that? has any1 ever heard of that happening?</TD></TR></TABLE>
Of course we've heard of it happening. It could be just your TOB, but chances are, it's the clutch too.
yea. mine recently did the same thing. go pick up a clutch kit. u get clutch pressure plate and throuwout bearing. and alignment tool. lik $130 for a cheap one. and make sure u take a like 60-80 grit sanding block and sanding the **** off yur flywheel. or just have it resurfaced.
