I need help with a code. ASAP
I have a 91 crx hf with a si motor and tranny swap. ( D 16a6) At mid range rpm's it sputters and bucks, and the ecu reads 1 single and 10 single.(1 1111111111) No one knows what the problem is. I need help today if able. Thank you
Well you have to count the number of flashes, then the pause, and you also have to tell us the number of long flashes / short flashes. Think Morse code
what ECU is it...either HF or SI same so "same codes" 1 = oxygen content and 10 is intake air temp...but normally 10 is abbrieviated with a long flash make sure its not like 1 and 19 which is lock-up control solenoid valve
...if its another ECU "i dont know why it would be" let me know and ill find you the codes...
Tru_Shine
Aug 12, 2009 03:58 PM
