radio code will not work
Old Jan 20, 2007 | 08:51 AM
micah128's Avatar
Default radio code will not work
I have a 97 integra, the battery was disconnected and it asked for the code. I pulled out the radio to get the serial (FA031453) and went to both a Honda and Acura dealer to get the code. They give me the code but it DOES NOT WORK. I am very confused at this point.
Does anyone know why the correct radio code would not take?
Old Jan 20, 2007 | 09:49 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: radio code will not work (micah128)
First, call them back and state you were given a code for your radio and it doesn't work. Worst case scenario, you will have to go back.
It could be as simple as the whomever gave you to code could have had a dyslexic moment and accidentally swapped two numbers. I don't know.
Old Jan 20, 2007 | 10:05 AM
micah128's Avatar
Default Re: radio code will not work (Jason M)
The crazy thing is that both the Honda dealer and the Acura dealer gave me the same code so I feal a little stuck.
Old Jan 20, 2007 | 10:16 AM
95 integra's Avatar
btw, you didnt have to pull the radio to get the code. Also, after 3 failed attempts (or something like that) there is a 24hr wait period before you can try another code....just incase that might be the problem.
Old Jan 20, 2007 | 10:34 AM
Default Re: radio code will not work (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by micah128 &raquo;</TD></TR><TR><TD CLASS="quote">The crazy thing is that both the Honda dealer and the Acura dealer gave me the same code so I feal a little stuck.</TD></TR></TABLE>
Try this:
With key in the "ON" position:
1. Turn radio on.
2. Press and hold the "1 and 6" "preset station button on radio.
3. Radio serial# should show on display.
Check to see if the serial number on the display matched the one on the back of the radio.
You may also want to check for a sticker placed in one of the following places:
- Ash tray (inside or underneath)
- Grove box (outside left panel when the glove box is fully open)
This sticker should have your radio serial number printed on it.
Old Jan 22, 2007 | 07:35 PM
micah128's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason M &raquo;</TD></TR><TR><TD CLASS="quote">Try this:
1. Turn radio on.
3. Radio serial# should show on display.</TD></TR></TABLE>
I tried this, but since the radio is expecting a code, when I press the 1&6, it thinks I am entering a code. Do I need to hit some other button first?
This sticker should have your radio serial number printed on it.</TD></TR></TABLE>
No luck with these either, unfortunately.
Any other ideas on how to get the serial number without pulling the radio?
Thanks for the help...
Old Jan 25, 2007 | 04:32 PM
tw0n's Avatar
Try holding 1 and 6, then turning the radio on. But i heard this only works on newer models (2000+). Anyone know if theres a similar process for older integras?
Old Feb 20, 2007 | 11:14 AM
TYPE-R#945's Avatar
Default Re: (tw0n)
i pmed your code
Old Feb 20, 2007 | 11:25 AM
BG-Teg's Avatar
Default Re: (TYPE-R#945)
try contacin the fist owner of the car to see if the code was changed... that happened to me
Bikeman982
Feb 7, 2009 11:31 PM
hoang
Audio / Security / Video
Feb 2, 2008 04:46 PM
mrsnj20
Sep 5, 2007 03:35 PM
crx_ef8
Acura TL, RL & ZDX
Oct 3, 2003 09:03 AM
delacampos
Jul 3, 2002 07:21 PM
