Moisture In Headlight
I have an 02 Civic EX. Yesterday, I noticed that the driver side headlight has condensation or moisture inside the headlight on the lens. Anyone know if I can repair this or should I just start searching Ebay for a new headlight? Thanks!
is it oem headlight or did you open it to blackhouse?
regardless when that happens i just take out a light bulb and hair dry it out...it only happens in the winter for me...
or if you feel like doing something you can reseal it yourself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_Junkie »</TD></TR><TR><TD CLASS="quote">is it oem headlight or did you open it to blackhouse?
or if you feel like doing something you can reseal it yourself...</TD></TR></TABLE>
asking the same thing..
if its ebay then let it defog and seal it up with silicon or a sealent.
There could either be an issue with the housing sealant, or the rubber mating spots at the bulb plug housings. And if that is the case.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM »</TD></TR><TR><TD CLASS="quote">let it defog and seal it up with silicone sealer.</TD></TR></TABLE>
HeirApparent
Aug 31, 2008 07:06 AM
