engine shuts off after start up?
Any CEL lights at all at any time? The problems you're having are the same EXACT problems that I had with my Subaru Imprezza.. and ironically enough it all started when I went to the mall as welll. Weird. Anyway, my car through a check engine light, ran the code and it was a coolant temperature sensor. The thing is with that my cooling and air conditioning fans ran constantly from turning the car on to turning the car off. In this case I would possibly think the IAT or maybe the O2 sensor. To me I'm thinking it's something causing the motor to either think that it's warmer then it should be thus making the car starve itself for gas and henceforth why you have to give it gas. Same thing I had to do with the Subie as well. Hopefully someone else can chime in and give you some other opinions as well just to enlighten the situation, but that's what it sounds like to me. Good luck!
nope, no check engine light code was thrown. I don't think it's the battery or starter because they are able to start the car.....any others?
oilspot
Feb 24, 2009 10:16 AM
