FS: Socal, XS Engineering Power Pack Ignition Amp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The unit installs inline with the positive side of the coil(s) and “boosts” the input voltage all the way to 20 volts! This translates in to increased spark energy regardless if it’s mated to a stock or aftermarket inductive ignition system. Also, the need for and expense of multiple ignition boxes in multi-coil applications is eliminated as Power Packs are designed to work with single or multiple coils. With its state-of-the-art internal power regulation, the Power Pack’s output remains at or near 20 volts and up to 20 amps even when the input voltage dips below 12 volts – making it ideal for even racing applications where no alternator is used. Another one of the Power Pack’s key advantages is its compact size. Measuring only 3.5” x 4.5” x 1.5”, the compact Power Packs are a breeze to install even in the tightly packed engine bays of today’s cars. Furthermore, all Power Packs are fully epoxy encapsulated to survive the toughest racing environments.</TD></TR></TABLE>
This is XS-Engineering's version of HKS Power Ignition or AEM CDI Igniton. Asking $200. kain821@yahoo.com or call at 626 261 9414
MySelfAffliction
Jan 29, 2008 01:59 AM
