H22 N/A headers
Old Jan 19, 2007 | 07:13 PM
monster007's Avatar
Default H22 N/A headers
Made this for a customers H22 set up.
Old Jan 19, 2007 | 07:28 PM
9bells's Avatar
OG Fabricator
Default Re: H22 N/A headers (monster007)
Good stuff.
I have only ever seen megaphones on open headers...
Old Jan 19, 2007 | 07:38 PM
weiRtech's Avatar
OG Fabricator
i like the supports off the head flange on each runner, but wouldn't it be a bit stronger if they were vertical instead of horizontal gussets?
Old Jan 19, 2007 | 08:00 PM
RC000E's Avatar
Default Re: (weiRtech)
I like it......any chance this guy is gonna do a hp comparison versus anything available on the market or stock?
Old Jan 19, 2007 | 08:12 PM
monster007's Avatar
Default Re: (RC000E)
No, I don't think his doing that. But we will see.
It's just a gusset.
Old Jan 20, 2007 | 06:26 AM
dfoxengr's Avatar
Default Re: (monster007)
whered you get the small vbands?
Old Jan 20, 2007 | 06:38 AM
DaveF's Avatar
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">whered you get the small vbands?</TD></TR></TABLE>
i second that..
also, is that some sort of "quick release" on them ??
also x2.... lets see that racecar !!!!!!!!!!!!!!!!!
Old Jan 20, 2007 | 11:54 AM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">i like the supports off the head flange on each runner, but wouldn't it be a bit stronger if they were vertical instead of horizontal gussets?</TD></TR></TABLE>
I don't know **** about welding/fab, but i know a little physics, so i would guess he did that b/c it makes a triangle which is the strongest geometrical shape and acts as leverage to hold more weight up.
Old Jan 20, 2007 | 11:59 AM
DaveF's Avatar
Default Re: (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know **** about welding/fab, but i know a little physics, so i would guess he did that b/c it makes a triangle which is the strongest geometrical shape and acts as leverage to hold more weight up.</TD></TR></TABLE>
they would still be stronger the other direction, but then you would have no surface area where it was welded on..
Old Jan 20, 2007 | 12:11 PM
Fabman's Avatar
Lierley Fab
Default Re: (dturbocivic)
looks like wastegate clamps
Old Jan 20, 2007 | 12:19 PM
monster007's Avatar
Default Re: (Fabman)
mcmaster carr look for Quick-Clamp Tube Fittings.
Old Jan 20, 2007 | 12:29 PM
monster007's Avatar
Old Jan 20, 2007 | 12:31 PM
DaveF's Avatar
those are pretty cool.
now... on to the racecar... lets see some pics !!!!!
Old Jan 20, 2007 | 12:36 PM
monster007's Avatar
Sorry don't have any pics of the car.
Old Jan 22, 2007 | 07:13 AM
alterdcreations's Avatar
what are the primary size?
also what size is the third collecter before the megaphone and after
also more importantly how much????????????????
Old Jan 22, 2007 | 08:33 AM
onefstek's Avatar
looks good, did you keep it equal lenght?
Old Jan 22, 2007 | 12:40 PM
monster007's Avatar
Default Re: (onefstek)
It's equal. It is a large tube header. 1 3/4 stepping up to 1 7/8.
Collector before meg. is 2 3/4. Meg go from 2 3/4 to 3 1/2 then back to 3"
Old Jan 22, 2007 | 01:28 PM
i need something like that for the summer.
how much do you charge??
Old Jan 22, 2007 | 01:40 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: (alterdcreations)
Dam looking good. I like all the little bells and whistles it has.
Old Jan 22, 2007 | 04:22 PM
Toddz Grafixxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
i second that..
also x2.... lets see that racecar !!!!!!!!!!!!!!!!!</TD></TR></TABLE>
Those are called Tri clover clamps.They are used in sanitary tubing.Like dairies and cheese factories.The problem is that the gasket that goes in between the two fittings is rubber and will melt.So you need some kind of an O ring out of wire .
It looks to me like most of the header was made from sanitary tubing.
Old Jan 22, 2007 | 05:00 PM
shutta's Avatar
wouldn't stepping up to 3.5' and back down to 3" be un-necessary? why not just go straight into 3" you are basically creating one more obstruction for exhaust gas to travel aound?
Old Jan 22, 2007 | 05:25 PM
Default Re: (shutta)
kind of tricking the air flow
i am down to different things
with some pro 2's and 12.5:1 compression i feel it would work good
Old Jan 22, 2007 | 06:12 PM
monster007's Avatar
Default Re: (Toddz Grafixxx)
Yes it is Tri clover clamps. They have been modified so there is no need for the "O ring" and they are now zero leek. As for the rest of the bends I have them made, Can only get the sanitary tubing in half sizes, no 1 7/8's or 1 3/4.
Old Jan 22, 2007 | 06:54 PM
can you pm me with prices and availibilty
Old Jan 23, 2007 | 06:58 AM
h22silvia's Avatar
looking sick how mch whp gains did u get
