JDM ITR front with FMIC?
Old Jan 19, 2007 | 05:57 PM
B18CJDM ITR's Avatar
Default JDM ITR front with FMIC?
well i just got done putting my JDM Front on....came out great and then i go to put my FMIC back on and its another story. The bumper will fit with the intercooler on but then when i hook up the charge pipes it throws it all off. Now i do not want to cut the bumper (OEM JDM ITR) but i looks like that's the only way for this to work. Has anyone ran into this before and get around it some how? The charge pipes are hitting the "out side vents" of the bumper. Help would be great pics would be better thanks
Old Jan 19, 2007 | 06:00 PM
Dave_B's Avatar
How many row FMIC? Can you go to a smaller setup?
Old Jan 19, 2007 | 06:02 PM
Default Re: (Dave_B)
its a precision 600hp intercooler
Old Jan 19, 2007 | 06:09 PM
Dave_B's Avatar
Default Re: (B18CJDM GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CJDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">its a precision 600hp intercooler</TD></TR></TABLE>
Do you need one that big? What is your setup? My suggestion based only on speculation given the HP #'s of the intercooler is that you could probably go to a smaller one.
Old Jan 19, 2007 | 06:22 PM
well i mean its not so much the intercooler it self, its the piping thats making it not fit right
Old Jan 19, 2007 | 06:52 PM
DontBlink's Avatar
any room to make some new pipeing tucking it closer to the core support?
Old Jan 20, 2007 | 06:45 AM
MiraiZ's Avatar
Default Re: (DontBlink)
I had no problems
Old Jan 20, 2007 | 09:22 AM
SE3Pimp's Avatar
Default Re: (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I had no problems
i hate you. /jealous
Old Jan 20, 2007 | 07:12 PM
Default Re: (EndlessDc2)
did you leave your bumper in? and it also looks like you cut the inner part of the bumper near the grill...right or wrong?
Old Jan 21, 2007 | 06:29 AM
Old Jan 21, 2007 | 07:21 AM
migs's Avatar
You can make it work without cutting the bumper cover but it all all depends on how your FMIC is mounted. My bumper cover had to be cut but now it fits fine because I took the turbo off. NA life is much better.
Old Jan 21, 2007 | 08:01 AM
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">You can make it work without cutting the bumper cover but it all all depends on how your FMIC is mounted. My bumper cover had to be cut but now it fits fine because I took the turbo off. NA life is much better. </TD></TR></TABLE>
na life is good i love my all motor itr hatch
Old Jan 21, 2007 | 08:58 AM
red_crx's Avatar
It should fit in there without a problem....post a pic of your charge pipes, please
Old Jan 21, 2007 | 01:10 PM
Default Re: (red_crx)
i will tomarrow...camera is dead
for all the input
Old Jan 21, 2007 | 04:54 PM
well i got it all fixed tonight i think, went out and got some new charge pipes and re did alot of the piping. Basicly tucked everything in alot tighter to the rad support now. Everything used to be wide and now its tucked tight and it did the trick. Hard to see in the pics but here they are.........
Before with some wider piping.....
And now after with alot tighter of a plan....
and all this just to make this thing go round.....
just gota get some more charger pipes cut, fitted up and welded and ready to go
Old Jan 21, 2007 | 08:53 PM
Speed Infliction's Avatar
glad you got it to work. what is your setup by the way?
Old Jan 21, 2007 | 09:54 PM
racin jasin R's Avatar
Default Re: (Speed Infliction)
you can still see what i had to shave....
Old Jan 22, 2007 | 04:52 AM
Default Re: (racin jasin R)
yahh im only going to have to cut where the end tanks are....very little cutting needed now
Old Jan 22, 2007 | 04:50 PM
MiraiZ's Avatar
Sorry for the late response...nothing was cut. Everything was pretty much plug and play, but I must warn you that my car's bumper support is much smaller than the USDM ones. So that might account for more room to install the FMIC
Old Jan 22, 2007 | 05:17 PM
SlapSmak's Avatar
I would suggest you install twin tfal fans considering the massive wall you have installed which will limit the radiators cooling ability. That IC is big enough for a Supra.
Old Jan 22, 2007 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the late response...nothing was cut. Everything was pretty much plug and play, but I must warn you that my car's bumper support is much smaller than the USDM ones. So that might account for more room to install the FMIC</TD></TR></TABLE>
it seems like everything i do, nothings working
Old Jan 22, 2007 | 08:52 PM
LowTEC-Derbo's Avatar
one of my roomate's crew's old R had a FMIC
if you can see it..
Old Jan 22, 2007 | 08:58 PM
Default Re: (LowTEC-Derbo)
very hard to see.....
Old Jan 22, 2007 | 09:05 PM
i gotta find better pics
edit:
here
Old Jan 22, 2007 | 09:10 PM
the ic piping connected to the intercooler is welded on or together rather than using the cuplinks.made the bump fit easier...
