FS - Built H22
Old Jan 19, 2007 | 03:30 PM
4bangin's Avatar
Default FS - Built H22
H22 motor (pushes water):
H22 block with darton DS-200 sleeves, CP pistons 10:1, eagle rods, 20 mile on OEM water and oil pump, acl bearings.
H22 head crower ss valves, jg retainers, skunk2 cam gears and head studs.
complete NO INJECTORS or FPR
Block #: 1007112
COLD COMPRESSION TEST ON THE MOTOR
255 255 260 265
$1800
M2F4 H22 transmission with Quaife LSD has slight leak nothing alittle jb weld couldnt fix.....slight grind in Reverse but other wise great condition..comes with STR scatter shield.
$950
3" aluminum intercooler pipes with greddy BOV (stiff spring) and flange welded comes with all couplers and T-bolt clamps. should fit B-series swaps also. $350 FITS B/H series swaps in civics
I can get photos of anything. PM me or email me at BurnYourFate@aol.com
Thanks!
Located near Atlanta, GA
Old Jan 22, 2007 | 04:41 PM
axlline's Avatar
Default Re: FS - Built H22 (4bangin)
Bump, pushes water?
Old Jan 25, 2007 | 06:51 AM
4bangin's Avatar
Default Re: FS - Built H22 (axlline)
pushing water means....boost pressure is getting into the combustion chamber when it boosts. Water gets pushed into the overflow tank
Old Jan 26, 2007 | 01:56 PM
4bangin's Avatar
Will part head for $600
Old Jan 30, 2007 | 11:03 AM
tommiboy's Avatar
payment sent for the intercooler pipping. just waiting to hear back from you. thanx
Old Feb 2, 2007 | 03:42 PM
Evil-EK's Avatar
Default Re: (tommiboy)
pm sent.
Modified by BigBlockH22atch at 2:32 AM 2/3/2007
Old Feb 2, 2007 | 06:00 PM
tommiboy's Avatar
thanx got the tracking number...
DTownLuder
Dec 9, 2019 03:37 PM
Turbo_DOHC
Dec 25, 2014 07:47 AM
KurtPierce024
Jan 12, 2013 02:08 PM
Nexus1155
Jan 27, 2008 06:26 PM
OaksRacing
Jun 26, 2006 04:07 PM
