multiple dash checklights 92 si vtec auto
Old Jan 19, 2007 | 03:28 PM
albundy's Avatar
Default multiple dash checklights 92 si vtec auto
after driving for about 1 minute the sport light flashes after another minute the 4ws light comes on then about 5 minutes later the engine check light comes on if i turn turn the car off and restart everything works ok for 1 minute and then the lights come back on at the same intervals and order also the speedo only works intermitantly and the tacho seems to stick at3000rpm untill i hit about 6000 rpm i cant retrieve the fault codes as everything works once ignition is turned off can anyone help please
Old Jan 19, 2007 | 08:24 PM
M2B4's Avatar
Default Re: multiple dash checklights 92 si vtec auto (albundy)
odd i thought the ecu stored cel codes until it was reset. have you tried checking the codes regardless. u havta turn to acc mode to test the codes ne ways.
alperx
Engine Management and Tuning
Sep 4, 2011 08:35 PM
arrocha87
20
May 13, 2009 03:46 PM
Creepsjr
Jun 7, 2008 11:39 PM
-[95cxhatch]-
Aug 18, 2003 08:01 AM
tdc
Jul 13, 2003 08:17 AM
