Got 175whp on the dyno again today. But this time MUSTANG dyno
B18C1 block stock sleeves 82mm
USDM ITR pistons
stock crank/rods
ACL bearings
B16A head milled .020
Skunk2 Pro Series 1 cams, Skunk2 cam gears
Supertech VS/retainers, stock valves
AEBS IM ported to ITR TB w/Hondata gasket
Profab header to 2.5" straight crush bent piping
3" intake w/BPi flow stack
chipped P28 tuned on crome by xenocron
shaved GSR crank pulley
310cc Precision injectors, Walbro 190lph pump, B&M FPR
93 Octane
MSD 6AL
First one is base run, second is final. What you think?
Revved it to 8600 but only shows up to 8k for some reason.
USDM ITR pistons
stock crank/rods
ACL bearings
93 Octane
MSD 6AL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">Why no more revs? That thing could still make more.. seems very peaky.</TD></TR></TABLE>
I'm pretty sure its just the dyno being out of spec
Numbers look low, but then again mustang dynos read lower then most.
Tq curve looks nice & flat. It would be interesting to see the results on a dynojet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
Yeah I might do that
</TD></TR></TABLE>Yeah I might do that
I don't see anything peaky about that torque curve. its actually one of the flattest I've seen (although that could be due to the scale). That said, torque isn't falling off at 8k, so it should be able to go some more revs.
Mustang dynos are notorious for reading low.
I think your making about 185 to 190 hp of a dynojet 248c. Either way that is some good power.
When the track opens, you'll be having some fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
I'm pretty sure its just the dyno being out of spec</TD></TR></TABLE>
had the same problem when i dynoed my car on a mustang dyno.
i got 186/124 with the original M22's (not m22x or m22xx) on a very similar setup to yours. and you have a better header then i do. i bet you could get a few more ponies if u revved it higher..
what did u set ur rev limit to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko »</TD></TR><TR><TD CLASS="quote">
what did u set ur rev limit to? </TD></TR></TABLE>
My tuner revved it to 8600 but the graph only goes to 8k for some reason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y »</TD></TR><TR><TD CLASS="quote">your tachometer could be reading high. Are you using an OEM tach? they are known to be off a bit.</TD></TR></TABLE>
Pretty sure its not off by 600rpms. VAFC (when I used to have it) recorded 86XXrpms when I revved it around there and we could see it on his laptop on crome.
I think the dyno just wasn't calibrated correctly
Mustang dynos will always read lower because they are more accurate to real life road conditions. It used the Cd of car to determine drag. 175 hp on a mustang dyno would be around 200 at the wheels on a dyno jet!!
here's the link https://honda-tech.com/zerothread?id=1720104 (pics are down though cuz my server is faaked!)
I stood and watched with my own eyes a guy run his CRX on a mustang dyno and it made 198 .He pulled it off the mustang and i followed him one block away to a dyno jet and it made 247.And did not change one thing.
Dynos are for tuning not for comparing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toddz Grafixxx »</TD></TR><TR><TD CLASS="quote">Dynos are for tuning not for comparing.</TD></TR></TABLE>
Can I get an "Amen." :hand placed next to ear:
I mean can I get an "Amen."!!! :Jumping up and down with hand placed next to ear:
I know, thats why I'm not going "OMGWTF!?!?!?! only 175whp!!?!?!?!?!waaahh" or anything.
Just sucks for bragging
btw, I've seen the RPM misalignment issue a million times with mustang dynos. Mustang dynos (like dynapacks or most other loading dynos) measure TORQUE directly and infer horsepower from torque and RPM. Dynojets measure acceleration, calculate horsepower and then infer torque from horsepower and RPM.
Most mustang dynos use a speed calibration procedure where you hold the car at 3000 RPM in the test gear and the dyno measures the vehicle speed in order to get the gear ratio used for calculating RPM during the test. If this test is not done 100% perfectly, you end up with a skewed RPM scale. Also figure that errors multiply with vehicle speed - at 9000 RPM, the car will be moving 3x as fast as at 3000 RPM, so any calibration errors will be 3x as bad.
Hope that makes some sense.
I like the torque curve, in any case.
Yeah, this dyno always seems to read the RPMs a little low...the other nuisance with the Mustang is that you have to setup runs conditions based on vehicle speed (from 20mph to 80mph or whatever) so you almost have to guess or log what actual MPH you are at hitting rev limit...in his case 8600 (77 mph in 3rd if i remember correctly).
The torque should read correctly but because HP is a calculated number based on Torque and RPM, the peak HP numbers are probably low as the dyno is using 8000 to calculate instead of 8600.
Dave, I might spend some time figuring out the inductive pickup and may need your help configuring it next time I am there, maybe some phone support
like said a dynos purpose is to tune you pulledsome good peak hp #s off of the tune so i would be happy!
the real question is How does it feel?
take it to the track and beat up on some people youll love it
jcvelez360
18
Nov 22, 2007 05:36 PM
SkoundrelUSA
29
Oct 9, 2006 08:03 AM
VtecKiDD
76
Nov 11, 2005 10:22 PM
