wont start...
Old Jan 19, 2007 | 01:56 PM
SoHc94's Avatar
Default wont start...
alright so my car has not ran for a while. been at a shop. he said timing valve adjustments and ECU. we did all of those. and my car still just cranks. and cranks. firing order is good. were getting fuel. and spark is there. i kant figure out what the expletive it is. but i got the following codes.
10-IAT sensor
19-Auto tranny lockup....
21-vtec spool
1st off. i hvae a manual tranny so im like WTF.
please help. im gettin mad.
Old Jan 19, 2007 | 02:38 PM
bart2546's Avatar
Default Re: wont start... (SoHc94)
I'd look into getting a new/used IAT from a junkyard or something and swapping it out. That helps control the air/fuel mixture to run your engine. If it's not sending anything or sending the wrong info it's going to cause you're car not to start. Other than that, if the timing belt has jumped a tooth or is broken it also will not turn over, but if you've looked at that and it's fine, I'd jump to the IAT first. The auto tranny one I cannot advise on because I am not familiar with it. Same with the vtec spool, so sorry I can't advise on any more than one item but hopefully someone else can help on those.
Old Jan 19, 2007 | 02:49 PM
Hi_Boost's Avatar
I have no idea
Old Jan 19, 2007 | 04:13 PM
SoHc94's Avatar
thank you bart. i will go look into those. the IAT is located where? its not the one on the back of the #1 runner is it? any diagrams? or pictures of it? thanks. and HI_boost if u dont know then dont reply that was a refuckindiculus post.
Old Jan 19, 2007 | 04:20 PM
my_slow_civic's Avatar
Vtec spool is the solenoid, IAT, is obviously air temp, and the auto tranny code, sounds like your ecu has been swapped.
The car will run with a bad IAT.
dc2doi
Jan 6, 2008 01:43 PM
blacksol95
Jun 11, 2006 01:16 PM
Lo-Buck EF
Aug 22, 2003 05:40 AM
oOPreludeBoyOo
Jul 20, 2003 08:11 AM
H23 Power
Jun 1, 2002 03:27 PM
