b16a almost complete
I have saved up all the parts and I want to knoe what am I missing. From people that have done this swap into their crx/ civic.
so far i think I am done.
1. B16a around 40k (head is already on the block) and torque down.
2. Itr Lsd (hydro tranny) I do have the convertion kit from hasport.
3. Shorter alternator belt for better clearnace
4. shift linkage ( bought from REDZONE proformance told it would fix)
5. Ebay motor mounts
http://cgi.ebay.com/ebaymotors...sting
( Notice that tranny mount is for cable trannys, but I do have the motor mount for the hydro tranny that I'm planning to use.
6. 90-93 rear L bracket
7. rywire.com wires OBD0 - Obd1
8. 94+ integra axles and halfshaft ( i was told i need to take the dust shield and hub out If i was going to use 94+ axles)
that is all i can think of as right now.
any suggestion on what I else I need?
well good so far BUT if your gonna go obd0 to obd1 you need a gray plug ECU,dizzy,four wire 02 sensor,and 0bd1 injectors,and the clips pretty sure,thats if the set you have was or is 0bd1??? MOE@HYPER16VALVE... but your close
gimme your itr tranny ?
No really it's a pretty stout setup I do recommend changing water and oil pumps and all filters while your at it and all fuilds
r.p.m
Jul 14, 2005 11:30 AM
handa
16
Apr 28, 2004 01:43 PM
