motor mount welded ... am i screwed?
Old Jan 19, 2007 | 11:09 AM
skateboard_ej8's Avatar
im hench irl
Default motor mount welded ... am i screwed?
i picked up this 91 EF with a B18b1 swap for 700 bucks.. done all half ***, and the guys i guess welded the "custom mount" to the car.. some people say im assed out cuz suposedly that makes the chassis weaker and i can no longer swap any other motors in there.. kinda need some expert help lemme know guys..
Old Jan 19, 2007 | 11:11 AM
EF9-CIVIC's Avatar
Default Re: motor mount welded ... am i screwed? (esco562)
pictures would help
Old Jan 19, 2007 | 11:39 AM
im hench irl
pics will be up tonite!! my bad.
Old Jan 19, 2007 | 11:53 AM
Reelizmpro's Avatar
Default Re: (esco562)
If you want to swap any other engine besides a B then yeah you'd be assed out if the mounts were rewelded. Then again you could always have stock mounts welded back in their original location. I don't see how it would make the chassis weaker.
Old Jan 19, 2007 | 12:16 PM
4thgenhtch's Avatar
Default Re: (Reelizmpro)
It makes it weaker because once heat is applied to the base metal its more brittle, Once is ok but if you go to cut off the already welded mount and reweld it again theres a better chance it could break... Bump For some Pics
Old Jan 19, 2007 | 12:25 PM
CRX Toad's Avatar
Default Re: (4thgenhtch)
If you cut it out you can always put in more metal on the reweld. Also back in the day people used to cut the mounts and move them to put a B-series in there. If that is what has occured just run with it.
Old Jan 19, 2007 | 12:49 PM
CroSi's Avatar
Sounds like a freaken headache to me. Sell the thing...
Old Jan 19, 2007 | 02:28 PM
Zaakro's Avatar
Default Re: (CroSi)
cut the spot welds off and put in new mounting points
Old Jan 19, 2007 | 02:33 PM
im hench irl
Default Re: (CroSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroSi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a freaken headache to me. Sell the thing...</TD></TR></TABLE>
awww but i just got the damn thing .. damn ill put up pics tonite so u guys can gimme your better visual opinions thanks guys
frizzle
10
Dec 7, 2009 08:11 PM
97grnrs
Aug 13, 2006 02:21 PM
fastcrx420
Mar 14, 2006 05:52 PM
swaplighter
Mar 2, 2003 03:21 PM
