what wireset do you have?
Old Jan 19, 2007 | 08:28 AM
Mr HYDE's Avatar
Default what wireset do you have?
what spark plug wireset do you have? im running msd wires not the msd system. i am breaking the prung on the wire that plugs into the dizzy. its weird! i have to keep taking it back to local shop where i got it from to have a new prung put on. any ideas why this is happing? i changed the cap and rotor and still does it.
post up what wireset you have for your boosted motor and any pictures?
i may just change wiresets
Old Jan 19, 2007 | 09:06 AM
a1320addict's Avatar
Default Re: what wireset do you have? (Mr HYDE)
oem
Old Jan 19, 2007 | 09:10 AM
Mr HYDE's Avatar
Default Re: what wireset do you have? (a1320addict)
anything aftermarket? what is oem? ngk?
Old Jan 19, 2007 | 06:26 PM
Mr HYDE's Avatar
ttt
Old Jan 19, 2007 | 06:32 PM
LSVtechnologytur...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">anything aftermarket? what is oem? ngk? </TD></TR></TABLE>
oem = original equipment manufacturer
Im using oem wires, no problems here. I think alot of people use them
Old Jan 19, 2007 | 06:40 PM
Mr HYDE's Avatar
Default Re: what wireset do you have? (LSVtechnologyturboboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVtechnologyturboboost &raquo;</TD></TR><TR><TD CLASS="quote">
Im using oem wires, no problems here. I think alot of people use them </TD></TR></TABLE>
thanks im very aware of what OEM means and what it is. i was asking what oem used. there own brand or like ngk or something
Old Jan 19, 2007 | 06:45 PM
Dunc's Avatar
BCICAN
I'm using the msd 8.5 wires. Never had a problem.
Old Jan 19, 2007 | 07:04 PM
Mr HYDE's Avatar
Default Re: what wireset do you have? (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">I'm using the msd 8.5 wires. Never had a problem.</TD></TR></TABLE>
thats what i have and i keep breaking the brass piece in the boot on the dizzy
Old Jan 19, 2007 | 07:06 PM
93turbo16's Avatar
I run NGK and OEM. Both i've never had any problems with.
But, never run the cheap autozone wires.. I hate tuning cars and having the stupid wires falling apart when I pull the plug wires to get to the plugs.
I the OP won't run them, but just FYI for some people how don't want to spend a extra $10 on wires.
Old Jan 19, 2007 | 07:08 PM
N20civicB18's Avatar
Default Re: (93turbo16)
MSD are the only plug wires for honda besides oem I have not had a problem with MSD
Old Jan 19, 2007 | 07:15 PM
Mr HYDE's Avatar
Default Re: (N20civicB18)
what the hell is going on with mine. it acutally looks like someone is bending and breaking the brass piece inside the boot. ths happened 4 or 5 times. ill get some pics of what i mean
Old Jan 19, 2007 | 08:56 PM
mike93eh2's Avatar
screw msd wires.. get some cheap ngk wires! trust me.
Old Jan 19, 2007 | 09:31 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">what spark plug wireset do you have? im running msd wires not the msd system. i am breaking the prung on the wire that plugs into the dizzy. its weird! i have to keep taking it back to local shop where i got it from to have a new prung put on. any ideas why this is happing? i changed the cap and rotor and still does it.
i may just change wiresets </TD></TR></TABLE>
oem, in my case summitomo or whatever they're called. oem ignition all the way
Old Jan 19, 2007 | 11:51 PM
1158's Avatar
NGK Blues...one step up from OEM NGKs
Old Jan 20, 2007 | 04:07 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (1158)
i run msd 8.5's zip tied to the cap, i have also used ngk blues. luck with both.
Old Jan 20, 2007 | 05:22 AM
HYREV2NR's Avatar
NGK's are great!
Old Jan 20, 2007 | 05:23 AM
mike93eh2's Avatar
Default Re: (1158)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1158 &raquo;</TD></TR><TR><TD CLASS="quote">NGK Blues...one step up from OEM NGKs</TD></TR></TABLE>
oem wires are not ngk
Old Jan 20, 2007 | 05:28 AM
Kev-turboEJ1's Avatar
Default Re: (mike93eh2)
NGK blues work fine for me, never had a problem.
Old Jan 20, 2007 | 09:38 AM
SpeedwaySlick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">I run NGK and OEM. Both i've never had any problems with.
That's exactly what happened to me on the dyno. My tuner said he'd never seen OEM plugs (like from an acura dealership) come apart, but I could get NGK blues and they would be just about as good.
You can get NGK blues here:
https://honda-tech.com/zerothread?id=831208
Old Jan 20, 2007 | 11:00 AM
Mr HYDE's Avatar
Default Re: (SpeedwaySlick)
thanks for the link. ill probably get a pair because i have no idea whats going on with my msd wires.
anyone have any idea why this could be happening?
Old Jan 20, 2007 | 11:10 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">thats what i have and i keep breaking the brass piece in the boot on the dizzy </TD></TR></TABLE>
Something isn't right then. Can you get any pictures of the brass connector before you put it on the distributor and then and after shot?
Old Feb 3, 2007 | 08:20 AM
Mr HYDE's Avatar
what do you think can be the problem. this has happened a bunch of times atleast 4 or 5 over 1 summer
Old Feb 3, 2007 | 12:09 PM
White Smoke's Avatar
i my honda
Global Mod
NGK Blues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">oem wires are not ngk </TD></TR></TABLE>
Actually, I think they are. I have heard that Sumitomo Electric makes the wires for NGK.
Also, some stock Honda wires say NGK on them
AlienKrOZ
Jun 14, 2007 07:20 AM
atmosphere
Sep 22, 2005 12:53 PM
ochsy03
Jun 26, 2005 09:47 PM
kevino002
Jun 7, 2005 08:26 PM
JoshuaVTEC
11
Jul 24, 2004 04:45 PM
