Anyone had this happen to them?
Old May 15, 2002 | 07:06 PM
Ibuprofen's Avatar
Default Anyone had this happen to them?
i was changing my oil (5w30 max life ) and while waiting for oil to drain, i removed the ft upper strut bar for no apparent reason and when i was screwed nut back on, i snapped one of the screws on the chassis for the nut! Now my question is, would this hinder the performance of the strut bar? On another note, I also stripped the lug nut while i was at it, broke the **** in my sink, and rip my pants. I dont care about the **** or pants, but now i dont think i can remove the kyokogen lug nut. Are there any tools that can remove stripped lug nuts?
Old May 15, 2002 | 07:10 PM
Bob#455's Avatar
Default Re: Anyone had this happen to them? (ITYP3R)
Damn, that sounds like a bad day...
I have heard of people stripping the strut bar bolts many times before...they are only supposed to be torqued to 17 ft/lbs (which feels like nothing).
lotus's Avatar
New User
Ouch.. Grab a beer and get someone else to fix it
Old May 15, 2002 | 07:11 PM
B2FiNiTY's Avatar
Man...I stripped one of the rear ones when I was installing my spoon rear strut tower bar. I ended up stripping my interior and kept on stripping it till I could no longer strip it anymore. Then I used a one size smaller socket and hammered it and my friend wrenched off. GOOD LUCK!
Old May 15, 2002 | 07:12 PM
B2FiNiTY's Avatar
Default Re: Anyone had this happen to them? (Bob#455)
17ft lbs? OMG...I tightened that sucker till it couldn't get any tighter...Time to buy a tq wrench.
Old May 15, 2002 | 07:16 PM
Ibuprofen's Avatar
I usually tighten that nut till my arms are shaking and my veins are protruding out...
Old May 15, 2002 | 07:17 PM
Bob#455's Avatar
Default Re: Anyone had this happen to them? (B2FiNiTY)
The front strut tower bolts are only supposed to be torqued to 17 ft./lbs., but I think the rear is like 49 ft./lbs. If you torqued the front until it couldn't go any tighter, you are lucky you didn't snap the stud...
Old May 15, 2002 | 07:18 PM
Bob#455's Avatar
Yeah, that's probably why people break the studs so often...
Old May 15, 2002 | 07:20 PM
B2FiNiTY's Avatar
I'm pretty weaksauce...so I'm guessing that I tightened them a bit much still though. Once I get my tq wrench, I'm retqing everything I ever took off.
Sassafrass
14
May 22, 2007 11:08 AM
Quetzolcotl
Oct 1, 2005 04:30 AM
VtecSpool
Suspension & Brakes
22
Feb 8, 2005 06:22 AM
Simple
23
Jan 23, 2004 09:28 PM
F120man
11
Jul 16, 2003 10:24 AM
