Valve Train Noise
Old Jan 18, 2007 | 08:16 PM
allmotor94teg's Avatar
Default Valve Train Noise
I have a all motor B18b with stage 2 gude camshafts. The top end is noisy when the car is running. I was just wondering if anyone else has had some noise from the top end with high lift cams. thanks
Old Jan 18, 2007 | 10:58 PM
youdontknowmeeither's Avatar
Default Re: Valve Train Noise (allmotor94teg)
is yor valve lash adjusted right?
Old Jan 19, 2007 | 12:01 AM
DS002's Avatar
Banned
Default Re: Valve Train Noise (zachlange)
Some noise is normal , even with valve lash adjusted correctly . I'd check the lash to make sure everything is sound , but if the lash is alright and it runs strong i wouldnt worry much about it . Especially running a more aggressive cam .
Old Jan 21, 2007 | 07:50 PM
Default Re: Valve Train Noise (DS002)
I have adjusted lash a few times and each time i did to the low end of the spec. It seems to run fine. So i think it will be ok
Old Jan 21, 2007 | 07:55 PM
bigislandc2's Avatar
yeah when i installed my jun 3 cams those were alittle loud as well. and after i played with valve adjusting noise was minimal. i forgot what mine were set at. make sure youre adjusting valves cold. but should also check the hot
Old Jan 25, 2007 | 09:32 AM
ls19integra95's Avatar
Default Re: (bigislandc2)
i have crower stage 2 turbo cams in my car and even with all the valve lash adjusted and everything new i still have quite a bit of noise from the cams just because they are so aggressive...
Old Jan 25, 2007 | 09:35 AM
mike5809's Avatar
Default Re: (ls19integra95)
I had crower 404's there like 3/4 strip. Anyway they are real agressive cam - they were pretty loud as well.
I would expect a little noise is normal even after everything is adjusted right.
GSRpoweredSI
Jun 16, 2007 07:33 AM
capzuk
May 2, 2006 12:32 PM
gsrjay
Aug 23, 2004 01:40 PM
infinkc
Jan 22, 2002 09:43 PM
