D15 head gasket replacment
hey guys
Just picked up an EG for $400 and it even came with a Blown headgasket. Do they make ARP headstuds for the D15? Would i be better off just going with the stock headbolts. Granted this has been twice before and seems like wrong twice before. Any info would be awesome.
Thanks!
Tom Z
Thanks!
Tom Z
im not sure if the head bolts in there are bad now but its been changed twice and that is torqued twice so im just gonna be safe, and i cant find ANY arp studs for a d15. Are the d16 interchangeable? thanks
what yes, just get 88-95 non vtec d16 headstuds. the OEM headbolts are only good once, and should not be reused unless checked with the proper tool (measures amount of stretch).
I am having the same problem with the coolant/exhaust gases. Did you need the special head gasket or did you use the normal OE gasket?
christian7750
39
Mar 5, 2009 09:49 PM
Turbo E
Jul 18, 2004 02:52 AM
HondaFanatic708
17
Apr 23, 2004 10:05 AM
