QUICK ?
Old Jan 18, 2007 | 05:11 PM
killerB16A's Avatar
Default QUICK ?
what should my cr be with type r pistons in a b16?
Old Jan 18, 2007 | 05:28 PM
Jay_Sensing's Avatar
http://www.c-speedracing.com/h...c.php
Kickass site for questions like this man.
And the compression will be lower. ITR's have a lower height than USDM and JDM B16 pistons.
Old Jan 18, 2007 | 05:31 PM
killerB16A's Avatar
Default Re: (Jay_Sensing)
i have seen two web pages like this and both of them say something diffrent?
Old Jan 18, 2007 | 05:42 PM
Well, one thing to be absolutely sure you can go to this site
http://www.kb-silvolite.com/calc.php?action=comp
But the others are idiot proof. For the KB calculator you need to know every dimension of your engine which you can find here by searching. It will give you both static and dynamic compression ratios.
The one thing that is for sure is an ITR piston will be a lower compression. USMD B16's are 6cc's of height to 6.9 for JDM versions. ITR's are 3.6 cc's of height and JDM ITR's are 5.9 so you are losing a little to a lot depending on what motor you are coming from to what ITR you are talking about. Either way, I would stick with B16 pistons.
Old Jan 18, 2007 | 06:28 PM
killerB16A's Avatar
ok i see what you are saying. people rant and rave over type r pistons to get higher cr i dont understand why?
civic-8442-
Jul 30, 2009 07:41 PM
o0o_tylor_o0o
Feb 27, 2009 08:40 PM
Jabinya
Jul 1, 2007 08:38 PM
chris2000
14
Feb 2, 2007 07:25 AM
lsvtec_hatchback
Aug 25, 2006 02:18 PM
