going to run nitrous with my turbo , how to seal the fitting in charge pipe?
Old Jan 18, 2007 | 04:48 PM
97grnrs's Avatar
Default going to run nitrous with my turbo , how to seal the fitting in charge pipe?
how can i seal the fitting that goes into the charge pipe near the throttle body because i dont want a boost leak , it comes with a nut to put under one side but that isnt gonna seal it 100%
Old Jan 18, 2007 | 05:06 PM
Boilermaker1's Avatar
If they're both aluminum, you could weld the nozzle in.
Any idea what kind of threads it is? Pipe threads will seal with teflon tape.
I'm sure you could use the nut and slobber on some JBweld and it would seal that way too.
Old Jan 19, 2007 | 05:53 AM
97grnrs's Avatar
Default Re: (Boilermaker1)
i guess ill put the nut on the bottom and use metal epoxy on top.. its the only choice i guess
z395civic
Nov 16, 2008 06:35 PM
hondaapi
Welding / Fabrication
Jul 4, 2006 08:21 PM
DB1_559
Sep 21, 2005 07:33 PM
ChillOutWayne
May 14, 2004 08:45 AM
birz
Apr 19, 2004 04:40 PM
