installing a tachometer
Old Jan 18, 2007 | 04:45 PM
civicdxguy's Avatar
Default installing a tachometer
i have no tach on my civic and was wondering on a scale of 1-10 how hard those are to install. its hard to know if my engine is being used to its full potential.
Old Jan 18, 2007 | 04:46 PM
egmatt93's Avatar
Default Re: installing a tachometer (civicdxguy)
Eran's Avatar
HT White Ops
The easiest is to just install a gauge cluster that already has a tach.
That falls at about a 2.
Also, a stock DX motor has zero potential except for fuel economy.
Old Jan 18, 2007 | 04:47 PM
4drgsr96's Avatar
easiest thing to get a tach and not look ricey is to buy an ex cluster cuz it already has the tach on there. maybe 50 bux?
Old Jan 18, 2007 | 04:54 PM
civicdxguy's Avatar
Default Re: installing a tachometer (egmatt93)
Thanks for the input
Old Jan 18, 2007 | 05:18 PM
ViSioN.GSXR.'s Avatar
Old Jan 18, 2007 | 06:43 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 &raquo;</TD></TR><TR><TD CLASS="quote">2</TD></TR></TABLE>
Wow, I was thinking the same exact # !!
Old Jan 18, 2007 | 06:54 PM
allricedout's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote"> Also, a stock DX motor has zero potential except for fuel economy.</TD></TR></TABLE>
atleast a dx has 16 valves.......my engine is a piece of junk.....but in reguards to OP, i did the ex/si cluster swap. and along with A black interior conversion
Old Jan 18, 2007 | 06:59 PM
BlueIntegraBoy's Avatar
EX cluster = 2
Aftermarket tach = 5
Old Jan 18, 2007 | 07:07 PM
and the cluster looks way better than a 5" tack sticking out of ure dash... it is also plug and play, no wire splicing.
Old Jan 18, 2007 | 08:02 PM
Felliph3's Avatar
Very easy,just lowers the steering wheel all the way,get a screw driver and unscrew 2 screws on top of the cluster youll see it,then take out the clock,a couple of bolts here and there and youre dash is out and now you can change the cluster.I think its something like that.Heres a write up:
https://honda-tech.com/zerothread?id=276819
https://honda-tech.com/zerothread?id=661308
how much do the si/ex/vx gauges go for by the way?
Old Jan 18, 2007 | 08:03 PM
Felliph3's Avatar
im not sure if the vxs had tach but apparently they do cuz they have VTEC.correct?
Old Jan 18, 2007 | 08:39 PM
Syndacate's Avatar
Default Re: (Felliph3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 &raquo;</TD></TR><TR><TD CLASS="quote">Very easy,just lowers the steering wheel all the way,get a screw driver and unscrew 2 screws on top of the cluster youll see it,then take out the clock,a couple of bolts here and there and youre dash is out and now you can change the cluster.I think its something like that.Heres a write up:
I think he was talking about a tach....like one of those 5 1/2" ricer ones from fast and furious - not a cluster w/ a tach...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">EX cluster = 2
Aftermarket tach = 5</TD></TR></TABLE>
EX Cluster = .3
It's 3 screws that hold the trim piece on, and 4 screws that hold the cluster in...and I think 3 plugs in the back?
Not exactly rocket science.
Old Jan 18, 2007 | 09:45 PM
Hemix's Avatar
Default Re: (Syndacate)
You can also get a Sunpro tach at autozone for $20 where the whole cluster is gonna cost atleast $150, if you're lucky.
Old Jan 18, 2007 | 09:49 PM
Eran's Avatar
HT White Ops
Default Re: (Hemix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hemix &raquo;</TD></TR><TR><TD CLASS="quote">You can also get a Sunpro tach at autozone for $20 where the whole cluster is gonna cost atleast $150, if you're lucky.</TD></TR></TABLE>
And the Sunpro tach is about $130 gayer than than an EX cluster.
Old Jan 18, 2007 | 09:57 PM
lluks_844's Avatar
Default Re: (Eran)
only hard part is findin the wire and splicing it in.
Old Jan 19, 2007 | 03:30 AM
Syndacate's Avatar
Default Re: (lluks_844)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lluks_844 &raquo;</TD></TR><TR><TD CLASS="quote">only hard part is findin the wire and splicing it in.</TD></TR></TABLE>
You look at a wiring diagram or the 1001 write-ups on how-to do it and simply match the wire colors.
Old Jan 19, 2007 | 05:23 AM
Castanza's Avatar
use a 1999 or 2000 civic si gauge cluster looks better and great for if you decide to do an engine swap down the road
Old Jan 19, 2007 | 08:59 AM
HbDrIvEr's Avatar
Default Re: (Eran)
HAHAHAHAHAHA!!!!!!!!!!!! THATS SO FUNNY!
Old Jan 19, 2007 | 05:35 PM
ifIexplode's Avatar
$150 for a cluster? where are you buyin yours
Old Jan 25, 2007 | 05:57 PM
Castanza's Avatar
Default Re: (HbDrIvEr)
how is that so funny when it clips right in and works
Old Jan 25, 2007 | 06:11 PM
jmeyer99's Avatar
Plug and play a gauge clust off of ebay.
First thing is to remember the single screw behind the hazard switch.
Don't drop thos screws into the dash or you will be ticked!
...and pry easy with two screw drivers on the hazard warning and the cluster bezel.
It's a must-fo swap!
Old Jan 25, 2007 | 06:16 PM
1234567899876543211230's Avatar
Indeed
Old Jan 25, 2007 | 06:29 PM
D16Clunkin's Avatar
i have a 97 dx and i bought a tach for 25 bucks and took me 20 minutes to install. your car is already pre wired for a tachometer. just pop the hood and look for the bllue wire on the right side near the firewall (if looking from the nose to the rear) and plug your **** up in the fuse box
http://www.summitracing.com
Old Jan 25, 2007 | 08:51 PM
HbDrIvEr's Avatar
Default Re: (Castanza)
if you saw who i was quoteing..... you would understand....... they way he said it was funny... but hey thanks asking!!!
