how to hook up exhaust temp gauge?
Old Jan 18, 2007 | 02:51 PM
ilovejdmhoes23's Avatar
Default how to hook up exhaust temp gauge?
how do you hook up a exhaust temp gauge? and also why does it matter what your exhaust temp is?
Old Jan 18, 2007 | 02:53 PM
Eran's Avatar
HT White Ops
You hook one up by welding in a new bung.
It matters because if you see the temperatures increasing under load, and then suddenly dropping, that's a big sign of detonation.
Old Jan 18, 2007 | 02:55 PM
Luserkid's Avatar
Default Re: (Eran)
I believe most company EGT that you get come with there own bung, i dont think the o2 bung will work. Also if your a b series you want it on the number 3 cylinder because it gets hot the fastest.
Old Jan 18, 2007 | 02:57 PM
Eran's Avatar
HT White Ops
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I believe most company EGT that you get come with there own bung, i dont think the o2 bung will work. Also if your a b series you want it on the number 3 cylinder because it gets hot the fastest. </TD></TR></TABLE>
Bah, that's what I was thinking of. Yes, they do come with their own bung (USUALLY).
Old Jan 18, 2007 | 03:05 PM
Luserkid's Avatar
Default Re: (ilovejdmhoes23)
You sure its not red green blk? Did it come with any instructions?
Old Jan 18, 2007 | 03:12 PM
Eran's Avatar
HT White Ops
Wait, you got an EGT gauge, and you didn't buy one that came with a probe?
Old Jan 18, 2007 | 04:00 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovejdmhoes23 &raquo;</TD></TR><TR><TD CLASS="quote">no bro can i just hook it up to a wire on the o2 sensor?</TD></TR></TABLE>
No. You really seem confused. An EGT gauge uses its own temperature probe, which is installed in the exhaust stream (normally somewhere on the exhaust manifold / header). This probe connects to the gauge, and the gauge is then also wired for power, ground, and illumination.
JDMgareth
Oct 18, 2007 11:23 AM
Knightmare69
Mar 24, 2005 09:54 AM
B18Flip
Jan 28, 2004 03:15 PM
navz121
Dec 5, 2003 07:24 AM
