jyt guys need help...
well i am still in the process of finding and buying parts for my JYT project. and i have come across alot of different sites , advice and here-says. the set up i was going for was(all on a ZC) Hf mani. T25 turbo, 450cc, S-afc, Starion intercooler, all necessary piping and gauges. planing to run about 5 or 6psi daily.
Well stopped in at a local shop today to p/u a gauge pod they do the majority of turbo cars in Az and they inquired about my setup. i told them the above and the informed me that 450cc inj would be overkill, and would cause me to run lean even with the SAFC. they also said from there tuning expriences with the SAFC and Vafc it only adjust to about 30 %, it adjust to 50% but the have never seen any changes after 30, and that it wouldn't help at all on my "set up".
There advice was to go with a vortech 12:1 FMU, 330cc injectors (from 1gen auto eclipse), and a few check valves, and maybe a SAFC if needed. they even said that the stock inj would be fine but as safety go with the 330cc. using a Zdyne ecu (a bit out of my budget).
anyone i've seen whose done the JYT has run 450cc, but the say it runs lean as hell with the Fp turned al the way down. so there reasoning to go with smaller injectors seemed to make sense (coming from a guy who had a 500hp supra, and various other turbo cars in the parking lot).
so does this make sense to anyone else? or are they trying ot somehow make a future sale off me? any advice fro the JYT guys. trying to do this as cheap as possible. i've checked the Forced induction section of the board but stil leaves my injector question unanswered.
Personally, I would go with a set of Dsm 350cc auto injectors (which are usually flowed at 380cc) (automatic 1g) and use the S/V Afc's to lean them out a bit. Tune with a Air/Fuel gauge to dial it in right, you might also have to play around with your base fuel pressure to get it to idle smooth and not run so rich.
I ran 380cc injectors with stock managment and FP down to 20psi, it ran very good but I got horrible milage and was very nervous if I was to wash the rings out.
A rising rate regulator and stock injectors are actually good to 5-6psi.. Might want to give that a shot too. But personally I dont care for them.
Good luck
Jeff Frank
Good luck
Jeff Frank
but i say this is utter bullsh!t...
for a JYT setup with the least mods go with what u initially had in your
head...ie 450cc DSM injectors...AFC hack mod.....etc etc...and
on a side note, its always better to get bigger injectors and tune them
down a bit instead of straining a smaller cc rate injector..!!
hth!
"on a side note, its always better to get bigger injectors and tune them
down a bit instead of straining a smaller cc rate injector..!!"
Actually, I have tried using the 450's with the SAFC and it did not respond to well to the larger injectors, even turned all the way down it acted very finiky, but maybe that was just me, I have done both... But if you score a good deal on the 450's its worth a shot.
Jeff
Jeff
